Lets set up a go fund me for Aaron’s transmission !!!
I had a deal on a 700hp capable dieselsite unit. It was in Cali and I couldn't get it arranged. I called dieselsite and unlike bts the warranty is non transferrable. To swap from 2wd to 4wd they wanted 1800$ to "rebuild" the unit. I can do the work but no warranty,needing swapped and the logistics not working out .. I'll save up for a bts.
"Sandy "is in the shop for pulling the engine and repairing fuel gauge that's inop
I'll snap some pics as I go. Lousy cyl head freeze plug. I have NEVER seen one fail on a 5.0. crazy stuff.
I adjusted on the doghouse tin. The hood to coul gap was huge on Dr side and tiny on pass. Loosened rad support at frame and everything else. Shoved core over,adj hood and got fenders better. Pass fender has a gap between it and door now at least. Lines look better too. Gotta move bumper over next. Fun times!
one more tidbit it got the power point swapped for some USB charging ports and the radio got an update as the oe tape deck no longer had volume control.
