Down draft tube for 1951 239
Old 03-24-2019, 08:27 AM
ynot321AB1
ynot321AB1 is online now
ynot321AB1 is gaining momentum as a positive member of FTE.
I have emailed LMC and NPD and MAC trying to find this tube and all I get is sorry. Can anyone advise where to find one?
Old 03-24-2019, 10:26 AM
Jersey devil's Avatar
Jersey devil
Jersey devil is online now
Jersey devil is starting off with a positive reputation.
Try Chris at Shoebox Central 405-259-9222. Chris is great guy, very knowledgeable and has both new and used parts.
hope this helps
tom
Old 03-24-2019, 11:36 AM
ynot321AB1
Hope this gets to the right person
THANK YOU FOR THE HELP IT IS APPRECIATED
Old 03-25-2019, 02:58 AM
OK F1's Avatar
OK F1
OK F1 is offline
OK F1 has a good reputation on FTE.OK F1 has a good reputation on FTE.OK F1 has a good reputation on FTE.
PCV Conversion
Are you looking to replace the road draft tube for originality or just for function?
Before I swapped my flathead for a 5.0, I machined a plug for the road draft tube and fit a PCV valve to it to pull the crankcase pressure out of the lower end of the motor. My road draft tube was clogged (well the upper half that I had was) and didn't function well. I was experiencing significant blow-by causing minor leaks and smoky exhaust. Once the conversion was done, all the blow-by and smoking was eliminated. It was almost a miracle cure!
If you are interested, here is a link to a similar unit for sale on ebay:
PCV Conversion
Here is the picture of the one I made (This was prior to installing to test the interference fit so it isn't fully inserted in the manifold)
Old 03-25-2019, 01:27 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
CharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant future
Road draft tubes have been outlawed in Calif for decades...it is such a source of air pollutants that I would figure that all states have jumped on the bandwagon by now. The rig that OK F1 shows essentially redirects the blow-by from the crankcase back into the air intake flow. Much cleaner solution.
Old 03-25-2019, 01:46 PM
chriscris's Avatar
chriscris
chriscris is offline
chriscris is gaining momentum as a positive member of FTE.
I have an extra if you end up still needing one.
$20 plus shipping
Old 04-05-2019, 05:18 AM
leonharu's Avatar
leonharu
leonharu is offline
leonharu is gaining momentum as a positive member of FTE.leonharu is gaining momentum as a positive member of FTE.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
