2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Back Rack Side rails and toneau cover
Old 03-24-2019, 06:32 AM
DAFBFD58's Avatar
DAFBFD58
DAFBFD58 is offline
DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.
I just got back into a truck from having an Explorer Sport for a year. At my work site there is a truck with the standard back rack and the bed rails. I want to put a cover on my truck, probably a retractable or roll up type.. The only hickup is the Back Rack Rails have a plate that goes down into the bed to completely cover edge. Looking at most of the covers they only cover a very little of the bed rail and simply clamp to the inside of the bed rail. My question is somewhat silly because Back Rack says you can not have a cover with their bed rails but I'm not sure why. Is it because that lip they have takes up to much space and the covers won't function properly or is it something else that i am not seeing. Most of the covers I have looked at require a shim of sorts because the ford beds have a taper to them. If I don't use the shim wouldn't the lip from the Back Rack rails act like a shim? Any thoughts on this?
Old 03-24-2019, 07:31 AM
cficare's Avatar
cficare
cficare is offline
cficare has a good reputation on FTE.cficare has a good reputation on FTE.
Installed TracRac with full length bed rails with a BAK Revolver X2 cover. Shim? Why?
There are several cover/rack combinations available HERE.
EDIT: I goofed. I didn't realize the OP was talking the brand "BACK RACK," so my initial reply is not applicable.
Old 03-24-2019, 08:46 AM
edjunior's Avatar
edjunior
edjunior is offline
edjunior is gaining momentum as a positive member of FTE.edjunior is gaining momentum as a positive member of FTE.
The BakFlip MX4 (and G2 and others) also do not cover the stake holes.
Old 03-24-2019, 09:12 AM
Hackenbush's Avatar
Hackenbush
Hackenbush is offline
Hackenbush has a good reputation on FTE.Hackenbush has a good reputation on FTE.
Old 03-24-2019, 09:25 AM
Hackenbush's Avatar
Hackenbush
The lip does hang over the inside of the bed rail too much if your talking about these
https://www.carid.com/backrack/full-...iABEgKN7vD_BwE.
I did try a set. Amazon easy return
Old 03-24-2019, 12:14 PM
DAFBFD58's Avatar
DAFBFD58
DAFBFD58 is offline
That is exactly the answer I was looking for. I thought about cutting the lip off but I'm sure it's there for a reason. I guess I'll keep looking for a solution
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
