5.8 upper/lower flow number results b4/aft dyno
Old 03-23-2019, 07:38 PM
torq'ta 5 8's Avatar
torq'ta 5 8
torq'ta 5 8 is offline
torq'ta 5 8 is starting off with a positive reputation.
So this will be long, not sure if moderators may have to split it up into 2 post, I've never done a new thread, but here goes.
2-3yrs ago I started looking for flow #'s for 5.8 truck, it could be out there but I have not found/seen it (EVER), you hear its junk, its trash, 5.0 truck flows way better, mustang guys used it, I've visited those mustang forums, never seen flow #'s for it(EVER), I have seen diy porting do one with flow #'s, I have read that TMOSS can port a 5.0HO to over 200-210 cfm,(just lower), so I set out to find 5.8 truck flow #'s finally got frustrated,and if all I do is complain about it, then I'm part of the problem, So I set out to find 5.8 upper/lower and do something, I know our Gurus on here have done the hybrid 5.8low/5.0up, with great success, and reading their builds, gave me the 'want to' like they had, and I want to thank each and every one of them, without doing names and leaving someone out, THANK Y'ALL! So unbeknownst to my redneck az, wores than needle in hay stack, but I had a buddy ask 'try JY where we grew up?' Doh! (load up!) JY had them ALL piled up in one big cluster cluck, owner said there you go welcome to look, REALLY! so made deal with him, every up/lo we put together in piles, I find 5.8 up/lo its free (rolls his eyes nods walks off) so for the next 4 weeks one day a week we go fight rattleheadedcoppermoccasin's and skeeters so big they had ticks on'em ready to burst, but I had my 5.8 up/lo, and buddy had 5.0 HO, now the fun begins, and the 5.0HO lower looks (eerily) similar to our 5.8 lower(see compare pics)
diy porting . com 5.0 HO lower
5.8 lower
its weird that the even ports (2,4,6,8) flow 190-207cfm
and odd ports(1,3,5,7) flow 151-186cfm, but with this in mind I worked on port 1,5, the most and port 4,8, only cleaned flash and gasket matched up/lo, only cleaned up ports to head (they had an hour glass shape instead of rectangle) I have not decided on heads I'm using yet, nothing that will require a tuner(big bucks) to me because I have a J.O.B.(keeps me J.ust O.ver B.roke) all the time, but first I got truck dyno'd here is whats done with more pics, 3" exhaust from last cat to 3" borla pro xs, si/so, and the intake hoses are wrapped with turbo blanket, and heat shield aluminum tape on snorkel at hood/rad, and a 2.5" hose where the I6/460 snorkel goes also,
hood/rad b4 6" wide
hood/rad aft 13" wide
turbo wrap
I6/460 hose 2.5"
where it comes out grill, beside radiator
with these mods already installed, I had it dyno'd in December, roll-up door was open for exhaust, skewed #'s? yes, but its a before intake install, and soon as weather permits and I can get off work to get swapped, I'll take it, [email protected],900rpm, and [email protected],800rpm
Old 03-23-2019, 07:58 PM
Squisher's Avatar
Squisher
Squisher is offline
Squisher has a good reputation on FTE.Squisher has a good reputation on FTE.
Cool stuff. Thanks for taking the time to share. Look forward to seeing the after numbers. Any pics description of the actual porting? How are you measuring the flow?
Old 03-23-2019, 08:09 PM
torq'ta 5 8
yes having to re-do may be too many pics at once will split up
Old 03-23-2019, 08:17 PM
torq'ta 5 8
heres before pics 160,000 gunk miles
lower b4 clean, port, polish
upper b4 clean, port, polish
throttlebodys b4 opening's 52.3-52.6mm
top throtlebody
bottom throttlebody
Old 03-23-2019, 08:31 PM
torq'ta 5 8
heres after pics, used blunt tip sharpie on upper, and used extra fine tip sharpie on lower you can hopefully see black lines on them, both upper/lower had a real egg shape instead of oval shape,gasket matched them and only rectangled(had hour glass shape) the intake to head ports, and flow #'s will show that I ported 1,5 a lot and 3,6,7 a little, and only cleaned up 2,4,8, of flash and polished all
throttlebody's opening after 55-55.7mm, (this is upside down and actually the left side)
right side you hit a wall and run out of roundness? (this is upside down and actually the left side)
Old 03-23-2019, 08:39 PM
torq'ta 5 8
flow #'s sheet I hope you can see, left column is before clean, port, polish, going down, then right side is after clean, port, polish, going down,
and this is with the upper/lower bolted together, I used a small shop-vac(harbor freight) 1hp, 2 gallon, 120vac, vacuum was, as follows
59km/h=36.66mph=281.54cfm, all ports were blocked off and tested one by one, blocking off each after test was done on each
Old 03-23-2019, 09:28 PM
Squisher's Avatar
Squisher
Squisher is offline
Great work man. I'll be real curious to hear your report on the after dyno runs.
Old 03-24-2019, 07:40 AM
Scndsin's Avatar
Scndsin
Scndsin is offline
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
I appreciate the work you're doing.
My chapter buddy is currently searching for a 5.8 lower for his upcoming build. (his has thermostat mount issues)
I'd like a couple myself. Where-bouts is your stash? Mussel Shoals?
While I like you're recording some numbers, what I promised myself I'd do next time was CC' the runners before any grinding.
My next one I want to get some volume numbers first.
Also would like to find some hard info on building up runners with epoxy.
I had an article on building up #1 & 5 on the outside with aluminum but it's gone.
Carry on...
Old 03-24-2019, 01:02 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Nice work there, really shows what a simple clean up can do. Are there any plans to further work the lowest flowing ports so that they all flow more similar numbers? I suspect the lower section is responsible for most if not all the differences.
Old 03-24-2019, 04:18 PM
torq'ta 5 8
Quote"Scndsin "Where-bouts is your stash? Mussel Shoals?"
Its called Leighton, AL,(25 mi, S.E. of muscle shoals) he is actually on top of LaGrange Mountain(Civil War Reenactment every year), Baileys Salvage, the 2nd place was in Zip City, (Florence, Al) not sure whats happen, but its closed up, I'm chasing phone #'s trying to get back there(been over a month or 2) all sign says "not doing well"? and thats never good, I get mine on and he still dont have one, I'm 45 minutes from Corinth? I'm wanting to go, if I ever get off again(launching new products), corinth salvage, alcorn salvage, and lambert salvage(booneville, ms). Oh! LaGrange is where Dawson's Moonshine Distillery just opened up is! lol! I wish my Tig skills was good enough to do aluminum, I've done Mig with the small spool, just to cumbersome, for small area for me to do. I've seen it done TMOSS has a site, but I cant get it to do anything, but he's working on it. He has cut upper 5.0HO down and kept stock look.
you ever here of The Mod Shop in florence, al, thats where dyno was done
Old 03-24-2019, 04:29 PM
torq'ta 5 8
[QUOTE=Conanski;Nice work there, really shows what a simple clean up can do. Are there any plans to further work the lowest flowing ports so that they all flow more similar numbers? I suspect the lower section is responsible for most if not all the differences.[/QUOTE]
I need that piece that 'diy' uses to get the thickness checked on short side of 1, 5, and a carbide bit that is a bigger ball to reach on each side, I also have a piece of Delrin thermoplastic, I'd like to try and use, I remember seeing you say about a phenolic spacer needing to be at least 1" to maybe see a change, my piece is 1 1/4" thick? maybe? cant believe no spacer for our trucks 5.8 "Imagine that"
T
they cut threaded piece, and made a stop
This is what I dont know the name of they modified one, you can gauge hole by running thread piece to check thickness inside port, anyone know name of this contraption?
Old 03-29-2019, 08:13 PM
torq'ta 5 8
Angry
update, took Conanski advise/suggestion, and went back in, got lower a little better, (maybe?) So my home ported 5.8 intake(boat anchor, junk, trash) on this week, and headed to get dyno'd, got hooked up, going thru test, and fuel pressure was at 47psi(holy carp), talk about black smoke(son said looked like rolling coal LMAO!LOL!) so I got adjustable on order, and they didnt even charge me, said to get it swapped come bake, they want to see what I gained/lost from stock dyno in December, see pic for new flow #'s, Thanks Conanski!
I just marked thru first flow #'s and wrote in new #'s under old
Old 03-30-2019, 03:45 AM
Scndsin's Avatar
Scndsin
Scndsin is offline
Originally Posted by torq'ta 5 8 View Post
...This is what I dont know the name of they modified one, you can gauge hole by running thread piece to check thickness inside port, anyone know name of this contraption?
Calipers. The original kind. 2 varieties, inside & outside (illustrated)
Measure between tips.
Old 03-30-2019, 05:51 PM
torq'ta 5 8
Thanks Scndsin! They somehow cut (threaded rod part, then drilled out the threaded hole and put threaded rod back through drilled hole with nut so they could measure inside intake runner, adjust nut til it touched the handle, then remove and check thickness, with it, I on the other hand, had redneck injenuidiy(?) smartness (I can spell that) cut coathanger, bend into shape, made two tape marks to check in same place, check marks with dial calipers then I remove it, hold marks on dial caliper and measure distance at tip with tape measure, crude but but I was able to know I had more on short turns than I thought. flow improved, we'll see shortly,
Old 04-04-2019, 07:59 PM
torq'ta 5 8
Updated, dyno #'s
Last week , had fuel pressure issues, got that fixed with adjustable installed, and it being a rainy miserable day is like watching paint dry, lets go get dyno'd, 'LOADUP' and so you dont have to hunt for stockish hp/tq, here it is - 171hp @ 3,900rpm, 278tq @ 2,800rpm timing set @ 13* with the wider radiator snorkel, and 2.5" hose add at I6/460 grill hole, stock exhaust manifolds, stock converters, and 3" exhaust, borla pro xs 3" si/so muffler, then swapped home ported 5.8(boat anchor, junk, trash) and first pull 36psi fuel-177hp @ 3,800rpm, 282tq @ 2,900rpm, second pull 34psi fuel-183hp @ 3,900rpm, 293tq @ 2,900rpm, I do not know what real flow #'s on a stock 5.8 upper/lower bolted together is, but with what I had to throw together and start point(before) and a stop point(after) using same method, I believe that our 5.8 intake has potential, and someone with more knowledge than me, could get more out of ours, and you dont need $800 for a edelbrock upper/lower, not knowing what it's hp/tq potential is with no other mod, I have only seen the 34ft.lb claims for it and heads(top end kit), again THANKS! to our FTE gurus, doing the hybrid 5.0up/5.8lo, I would not had a clue where or how to start, I was just tired of looking and no #'s to be found for it, and instead of complaining and being part of the problem, I've tried to make a showing.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
