Mothers CMX ceramic wax
I was curious if anyone has used this product on their truck and how did it perform. It's a fairly new product.
Mothers CMXâ„¢ Ceramic Spray Coating
I have used the Maguiars competitive product to this Mothers version.
I think it works ok. It dies add some pretty amazing hydrophobic water beading and shine. It just doesn’t last long. Maybe 2-3 car washes and most of it is gone. I use the spray and wipe it back in and the protection is restored.
This experiment with ceramics convinced me enough to do a proper ceramic coat this spring.
Esoteric out out of Ohio has great info on their website.
No sir. Beadmaker is the easiest to use product ive come across. If its been a while, i wash then clay bar. I dry the vehicle completly. 2 micro fibers, one dry, one moistened with the maker. Spray the panel, and work it with the moistened micro. Come back with the dry micro flipping often. No streaks, no mess. For maintenance i wash, and then use as a drying agent, spraying lightly across the panel and using micro fibers to dry. Super EZ. Personally i love the stuff. Makes my ol ladys black JK Wrangler look like a frikkin’ mirror!
try gtechniq c2v3. It lasts a long time compared to others. I put a coat in last December and just washed the car last week and is still beading great. Super easy.
If you want a great shine and long lasting protection check this stuff out.
https://www.autogeek.net/klashiggloss.html
it only take a small amount. Less is better. Let it dry about 15 min. Not longer. I wipe off using a spray sealant or spritzer.
Last St summer I had found bird poop on my hood after the truck was parked in August sun nearly the entire day. It was baked on.
Zero etching and and you can’t tell the bird droppings were there.
It’s economical also. Probably get 5 to 6 treatments on a super duty out of one bottle. Not bad for $20.
