1990 460 Econoline 350 engine swap to 1990 F350 5.8
Old 03-18-2019, 10:49 PM
hilly7
hilly7 is offline
hilly7 is starting off with a positive reputation.
I located an Econoline 350 Box Truck that has a 7.5 in it. Can this work in a F350 to replace a 5.8 and what would need to be changed? I notcied the breather box on top instead of the fender well but aside from that could see too much around it. Is this doable with minor modification of should I contiue looking for another F350?
Thank in advance.
Old 03-18-2019, 10:58 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
It could work but you need the big block trans too as that motor won't bolt up to the one behind the 5.8, also need the 7.5 PCM.
85e150
85e150 is offline
85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation
Nothing minor about it. Two different engine series, different transmissions, exhaust, cooling and a host of others. Are you trying to repower your F350 to replace a blown engine or just to get more power?
Old 03-19-2019, 04:10 AM
hilly7
hilly7 is offline
A little of both. I'd like the added power but also the 5.8 is about to it's end.
Old 03-19-2019, 04:15 AM
hilly7
hilly7 is offline
It is a complete truck so the trans is there too. New box, brain, distributor, runs good. I just noticed what I saw on the top of the engine was a whole lot different than a F350 and crawled under it and saw a lot of difference.
Old 03-19-2019, 08:13 AM
hilly7
hilly7 is offline
Would the trans & engine volt in place of the 5.8 and also would the air filter and stuff on top of the engine be hard to transfer to the fender well?
Old 03-19-2019, 08:27 AM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
My4Fordtrucks is gaining momentum as a positive member of FTE.My4Fordtrucks is gaining momentum as a positive member of FTE.
Originally Posted by hilly7 View Post
...would the air filter and stuff on top of the engine be hard to transfer to the fender well?
You don’t need the air box from the van. You would only need to locate OEM 460 tubes or fabricate tubes to go from your current air box to the throttle body.
Old 03-19-2019, 11:11 AM
hilly7
hilly7 is offline
Thanks. Will the mounts for the engine & transmission bolt the same
Old 03-19-2019, 08:41 PM
hilly7
hilly7 is offline
[color=left=#222222]Thanks. Will the mounts for the engine & transmission bolt the same [/color]
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
