Shopping for a new truck / no limited slip
Howdy Fellas,
I'm shopping for a new 2018 / 2019 Ford F-150 Screw XLT 302A / 2.7 Eco and I need your opinion.
I found a good deal on a 2018... the only thing the new truck does not have is the limited slip / locking axle.
I drive 84 miles round trip daily to and from work. My current truck has the limited slip / locking axle. Meaning, when it rains I normally do not engage the four wheel drive. I've never had a control issue or spinout. Obviously, I engage the four wheel drive in the snow.
What are your thoughts of buying a new truck 'WITH OUT' the limited slip / locking axle?
Appreciate you input.
Limited slip is now an expensive and limited availabilty option. The way the traction control works now some what mimics the way a limited slip works by computer controled brake application.
Another option is to buy a truck with an open differential and have your local shop install an aftermarket limited slip like a Detroit Truetrac
https://www.summitracing.com/search/...el/ford-8-8-in
For my money, the E Locker (which I have) is a waste of money unless you have a very specific need for it. It disengages at speeds above 25 mph in 4X2, 4X4 high and 4 auto. You're not going to use it in the rain anyway since there's too much traction for a locked rear. If you engage it in the snow you'd better like going sideways. One of the only good uses I've found for it is in muddy, rocky off road situations where you can't go very fast and can't slide sideways. It's also useful for pulling a boat trailer up a slimy launch ramp where the trailer keeps the rear end from sliding sideways.
As others have said, the current traction control and stability control systems in our trucks does a great job in rain and snow. I only have it because it came with the 3.55 rear.
