1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
intelligent 3 blink turn signal
Old 03-17-2019, 10:26 AM
mdayz28's Avatar
mdayz28
mdayz28 is offline
mdayz28 is starting off with a positive reputation.
I heard on You Tube someone was saying how they changed the 3 blink to a 5 blink on the 3 blink intelligent turn signal , Was wondering if anyone knew how to change it from 3 to 5 blinks ? I don't know if you need to go into the computer and change it like you need to do a forced regen on the 2016's ? Thanks for any help !
Old 03-17-2019, 10:31 AM
Just Strokin
Just Strokin is online now
Just Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud of
Yes, you have to use FORScan and an OBDII adapter for a computer/laptop to change it. I have mine set for 6 blinks with no trailer.
You can find the info here under the IPC tab.
FORScan 2016 Super Duty - Google Sheets
Old 03-17-2019, 04:55 PM
mdayz28's Avatar
mdayz28
mdayz28 is offline
Thanks , 6 sounds better than 5 but 3 is not sufficient ! Thanks for the response !
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
