Egr delete kit Opinion
Never heard of Max Flow diesel, but I'm curious why you're looking for opinions *after* you already bought it haha. If somebody is familiar with them, and tells you about a bad experience.....too late! Good luck man. I do see you will be able to tap into it with your egt probe. Use the probe off of your DPF.
I'm not 100% sure, but I don't think any of the SCT units will read it correctly. I know the SCT GTX does NOT read it correctly without an intermediate such as this from No Limit:
PIP EGT Sensor for SCT Products
They state ALL the SCT using the "firwire" - I assume that to be "firewire"- analog input on their site.
Having difficulty locating the DPF delete race pipe through the vendor that I'm getting the tuner and programmer From my question is I found them on flea Bay were it is not one whole piece but to pieces that joined together doesn't matter if it's 1 solid piece or 2 it shows that they are 2 mm thick thank you.. Yes I know badd punctuation run on sentences misspelled I'm doing talking text
