Egr delete kit Opinion
  #31
Old 04-14-2019, 07:53 AM
Bohen
Bohen is online now
Bohen has a good reputation on FTE.Bohen has a good reputation on FTE.Bohen has a good reputation on FTE.
Originally Posted by UP_There View Post
You remove it from the DPF, and re-use it on your EGR plate where the egt sensor will go.
Yep.
Thank you Sir👍
  #32
Old 04-14-2019, 09:47 AM
tradosaurus's Avatar
tradosaurus
tradosaurus is offline
tradosaurus is starting off with a positive reputation.
Personally I would recommend taking your truck to a reputable diesel performance shop, dropping off the equipment you bought, and let them install and tune your truck.
The shop near me does these installs frequently and the $600 labor was a piece of mind for me.
  #33
Old 04-15-2019, 09:14 AM
Chuck-B's Avatar
Chuck-B
Chuck-B is offline
Chuck-B is gaining momentum as a positive member of FTE.Chuck-B is gaining momentum as a positive member of FTE.
I learn something new here every day - Ford makes an EGR delete kit? Is this "plug and play" or you need to have the truck tuned?
  #34
Old 04-15-2019, 11:15 AM
RIPbiker13's Avatar
RIPbiker13
RIPbiker13 is online now
RIPbiker13 has a very good reputation on FTE.RIPbiker13 has a very good reputation on FTE.RIPbiker13 has a very good reputation on FTE.
No matter what you do, the truck needs to be "tuned" in that it will not check for the EGR valves. Also, no EGR would mean the DPF will clog even faster and kill the engine if you didn't remove it.
To add real quick, the dealer diesel tech told me it isn't the EGR or the DPF that kills the engine, it's the temps the engine gets up to during the regen cycle that does the damage.
  #35
Old 04-15-2019, 08:29 PM
Overkill2's Avatar
Overkill2
Overkill2 is offline
Overkill2 is gaining momentum as a positive member of FTE.
Originally Posted by 2011350diesel View Post
Has anyone seen the Ford oem egr delete? has anyone used this? BC3Z 9P449 A67
Dude, I have been all over that site every which way but loose and I can't find that kit.
  #36
Old 04-16-2019, 04:34 AM
2011350diesel
2011350diesel is offline
2011350diesel is starting off with a positive reputation.
When I had done a google image search I saw the ford delete.Didn't realize that they even made one , soo... wad curious to see if anyone had heard of this or maybe had even used one
  #37
Old 04-16-2019, 05:03 AM
Bohen
Bohen is online now
fleabay sells one but it's for the 11-14 : /
  #38
Old 04-16-2019, 08:14 AM
dirthawg's Avatar
dirthawg
dirthawg is online now
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
I wonder if this is the same kit? Not much info on it.
https://parts.autonationfordwhitebea...IFJlc3VsdHM%3D
  #39
Old 04-16-2019, 09:02 AM
Overkill2's Avatar
Overkill2
Not in the market now, just curious though.
Yeah I saw that too. Just no pic kinda s*cks.
  #40
Old 04-16-2019, 09:22 AM
RIPbiker13's Avatar
RIPbiker13
Is it possible that that kit is some sick b**tard's idea of a prank?
  #41
Old 04-16-2019, 03:03 PM
doczenith1's Avatar
doczenith1
doczenith1 is offline
doczenith1 is starting off with a positive reputation.
Hmmmm, I don't think the added fuel during a regen ignites until it's past the turbo and in the exhaust stream. There should be no reason for the engine to get warmer during a regen. I'm not a diesel expert but that's my understanding of how the regen works.
My buddy did my EGR delete. I'm not sure what probe this is but I'm certain it didn't come from the DPF.
After the delete my EGT11 (post turbo) and EGT12 are static at 122 degrees and EGT13 and 14 are static at 842. Is this because of the custom tune? And that would explain why you need an aftermarket probe to get EGT's after a delete?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
