99 F350 7.3 Electrial Problem - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-15-2019, 03:57 PM
JoeLawrence73
JoeLawrence73 is offline
JoeLawrence73 is starting off with a positive reputation.
My F350 will not start without being jumped. When the truck is off both batteries read at or slightly above 12.5 volts. When it is running after I jump it, they read 14 volts.
Any ideas as to why this may happen? Could it just be the starter going bad? It is original.
Old 03-15-2019, 09:06 PM
oharal
oharal is offline
oharal is starting off with a positive reputation.
What's the date code of manufacture on the batteries? No load voltage doesn't tell you anything about the health of the battery, only that it is charged. They could be worn out and have high internal resistance. You can check with your multimeter. What does the voltage drop to when cranking? Additionally, be sure to check ALL of the connections from the B+ on both batteries all the way to the starter post, and B- on both batteries all the way to the engine block.
Old 03-15-2019, 10:43 PM
99f350sd
99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
Sounds like the batteries are toast. Voltages are good. More than 4 or 5 years old?
Old 03-16-2019, 10:22 AM
alloro
alloro is offline
alloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud of
It needs to be jump only when sitting a long time like overnight, or even when you run into a store for 10-minutes and come back out?
Old 03-16-2019, 11:33 AM
Fefanatic
Fefanatic is online now
Fefanatic is starting off with a positive reputation.
Overnight is not considered a long time by any means. The battery can have good voltage but not have any cranking amps. If you are reading 14 volts while running the alternator is good. Time for new batteries.
Old 03-16-2019, 05:17 PM
TrucksNCoffee
TrucksNCoffee is offline
TrucksNCoffee is starting off with a positive reputation.
Used to be that auto parts stores would test your battery with a load tester they kept on hand, free of charge. Smart move, this, 'cause if the battery needs to be replaced, you're already there and they'll sell you one, on the spot.) I think they still do this, no?
Old 03-16-2019, 11:36 PM
burnthelight88's Avatar
burnthelight88
burnthelight88 is offline
burnthelight88 is starting off with a positive reputation.
7.3 needs a minimum of 10.8 volts while cranking to start, resting voltage doesn't mean much at all. I'd say your batteries are obviously toast. Yes, most stores will load test them for free. If only one tests bad, still replace both.
Old 03-17-2019, 12:17 PM
alloro
alloro is offline
It's enough to determine if there's a different result versus sitting 10-minutes. Which in turn could change the focus from batteries to the starter or not.
Old 03-17-2019, 05:18 PM
1Truck
1Truck is offline
1Truck is starting off with a positive reputation.
Your batteries read 14v while running because you are reading the voltage being produced by the alternator. You can have a dead cell which eventually could prevent the truck from being jump started. This would also cause the charge to rapidly deplete.
you could also have a bad alternator which is draining the battery. Replace batteries, if problem persists, replace alternator.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
