2004 F250 Rear Shock Bolts - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-15-2019, 11:12 AM
jlalanas's Avatar
jlalanas
jlalanas is online now
jlalanas is gaining momentum as a positive member of FTE.
Hi All,
Anyone know the size of the lower rear shock bolts for this truck? Helping a buddy change his shocks this weekend and I know they are going to be really rusted so wanted to have a new set on hard in case we need to cut them off.
Thanks in advance.
Old 03-15-2019, 11:29 AM
Djosbun
Djosbun is offline
Djosbun is starting off with a positive reputation.
I just did my 2005 F350 dually last weekend and they were 8mm (lower) and 15mm (upper) if I recall correctly.
Not sure if the 250 would be the same.
Dave
Old 03-15-2019, 11:39 AM
JG6.7
JG6.7 is offline
JG6.7 is starting off with a positive reputation.
Depends on year. my 2016 lowers are 18mm nut, 15mm bolt. Upper is an 18mm nut with a non removable stud.
The lower bolt and nut + upper nut are to be disposed and replaced anytime they are removed anyway (per workshop manuals). They stretch over time, just side to side leverage from the shocks.
Really, any suspension hardware should be replaced after its been removed. Cheap insurance imo.
Old 03-15-2019, 12:27 PM
jlalanas's Avatar
jlalanas
Thank you!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
