motorcraft 2150 off idle hesitaion
Old 03-15-2019, 10:43 AM
bryanA73's Avatar
bryanA73
bryanA73 is offline
hi guys, I need some help on carb issues. I have a 1973 F250 with a 360 and a Motorcraft 2150, I rebuilt it a couple weeks ago and cant seem to adjust my way our of this off idle hesitation issue. I double checked the timing to ensure it was at OEM specs- that was good, I set the air/fuel mixture with my vacuum gauge ( at temp with vacuum advance disconnected)- that was great, no vacuum leaks, other then the off idle hesitation it runs great...like really great. I did notice if I drive it while the fast idle cam and choke are still engaged it doesn't have that hesitation. My thoughts are: with the choke on, its enriching the fuel mixture and decreasing the air, so the hesitation goes away due to the increased amount of fuel- does that make sense? so, I've adjusted the arm on the accelerator pump in a few different positions, currently its on the outer hole on the pump arm and the highest hole on the travel-over lever, it seems to like this position best. As far as getting more fuel to the carb, I'm out of options unless I re-jet it, right?. its the OEM carb, I cant imagine why it would now need larger jets? anyone have any advise? one thing to note is, it does have hefty exhaust leak, I don't know if that would effect anything? I plan to seal that up this weekend and see if that works some magic. Any advise would be great guys! thank you in advance!
Old 03-15-2019, 10:56 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
When you set the vacuum did you got for highest reading and then richen it out +1Hg" ? What hole did you put your accelerator pump arm in?
Old 03-15-2019, 11:12 AM
bryanA73's Avatar
bryanA73
bryanA73 is offline
when setting the vacuum, I threaded the air/fuel screws in *gently, and backed them out 1 1/4 turns as a starting point, then hooked up the gauge and turned them out about 1 full turn to get the best vacuum if I remember correctly, then I turned them clockwise 1/4 each ( this is what the OEM manual specified). sorry, I'm not familiar with +1hg? can you educated me on that ? the accelerator pump arm is on the outer hole on the pump and the #4 position on the traveler arm. thank you for your help!
Old 03-15-2019, 08:28 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
So, if all was well before you rebuilt your carb, then I’m guessing something may have gone wrong.
When you rebuilt, you checked/sprayed through all the orifices/holes/ etc.
All the parts go back in the way they came out ? Check Ball ?
You replaced the enrichment valve & gasket ?
I’m assuming your transfer slot is not blocked if it wasn’t before.
Great spray out of the accelerator pump ?
What do your spark plugs look like?
burkhart3
11-08-2017 09:02 AM
78 Ford F150 460
1978 - 1996 Big Bronco
42
01-24-2017 08:05 PM
Finmad
12-20-2016 10:08 PM
straightsixer
10-19-2007 03:32 PM
dbossman
04-05-2005 10:34 PM
Quick Reply: motorcraft 2150 off idle hesitaion
