'66 F100 Fuel Tank Removal - What to do with holes?
Old 03-15-2019, 04:10 AM
fun4evrusa
fun4evrusa is offline
fun4evrusa is starting off with a positive reputation.
Hello All,
Now that I removed my Tank from behind my seat, what do I do with the Tank Mounting Holes in the floor as well as the hole for the fuel line going to the Engine? Anybody know of any rubber seals or anything like that? I want to avoid welding them closed.
Thank you,
John
Old 03-15-2019, 04:33 AM
Crop Duster's Avatar
Crop Duster
Crop Duster is online now
Crop Duster is gaining momentum as a positive member of FTE.
There are no holes in the floor under that tank unless you removed the cab mount bolts. The fuel line hole is the only hole to plug.
Old 03-15-2019, 12:07 PM
dubya TF's Avatar
dubya TF
dubya TF is offline
dubya TF is starting off with a positive reputation.
+1 from what Crop Duster said- the bottom tank mounts are on the rear cab mount bolts. Throw those jokers back in there and tighten them down 3 ugga uggas.
Old 03-15-2019, 01:41 PM
SixtyFour
SixtyFour is offline
SixtyFour is starting off with a positive reputation.
Old 03-15-2019, 02:21 PM
daveengelson
daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
On both of my 65's there is a fuel line that runs along the top of the tank then down the side and thru the floor, in my case, forward to the engine compartment to a canaster fuel filter then to the fuel pump. Installed a grommet where the fuel line passes thru the floor and sections of frabric and/or rubber fuel line hose to minimize metal to metal contact thru cavities along the frame.
Old 03-15-2019, 05:19 PM
66v8baby's Avatar
66v8baby
66v8baby is offline
66v8baby is gaining momentum as a positive member of FTE.
Funny, I use 3 ugga uggas for something entirely different!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
