97 F250 7.5L/460 Evap hoses
Your computer said that was still the problem. I think it is the problem. You said it appeared to be fo Mo co. It should say motorcraft if its original Ford. If the shop guarantees their work, take it back. Tell him to run the codes and see that is the problem and he needs to replace it. Again, this is not uncommon. If it is still humming he may not have replaced it. That indicates it is stuck open. Sandy
