New owner of 86 F250 2wd
Old 03-14-2019, 07:32 PM
DeMartini
DeMartini is offline
DeMartini is starting off with a positive reputation.
Hi everyone,
I just bought a 1986 F-250 extended cab, 2wd. Has a 460, C6, Sterling 10.25 open diff with 3.55 gears. Solid Texas truck. It backfired and then sucked a butterfly in and bent a valve (prior to purchase).
Iíve got three stages planned:
1) pull motor and replace heads, install RV cam, aluminum intake, Holley 4 barrel, headers. Hope to just get her running and a little warmer.
2) single turbo with blow through carb. I have a cheap option on a turbo that is probably a little small (75mm compressor). Iíd love 500+/650+ for hp/tq.
3) Lower with bags in the rear and crown Vic front end.
4) Interior updates, replace rear jump seats with a bench.
Iím hoping to make a low and fast kind of rig, like a freight train.
Anyone done anything similar? Iíd love to hear anything about lowering given that there arenít any off the shelf lowering beams that i can find.
TD
Old 03-14-2019, 08:10 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The crown vic front end isn't a slam dunk like it is in the earlier trucks. These trucks are wider. But with a little fabrication it can be done. Will you keep your original rearend and put some sort of adapters on it for the lug pattern? Or change the rearend out?
A turbo on a carbed engine is not the easiest thing to do. I assume you know all the work required to do it.
Old 03-14-2019, 08:34 PM
DeMartini
Thatís good to know about the crown Vic front end. Are there other ways to do it?
Ill be getting a lot of help from a friend friend who knows a lot about these motors and can do fabrication. This is definitely a learning project for me.
Old 03-14-2019, 08:56 PM
Franklin2's Avatar
Franklin2
What type of front suspension do you have? This company makes these, but they are for 87-up only. I don't know what the difference is on your 86.
https://djmsuspension.com/product/db3005-3/
Old 03-14-2019, 10:49 PM
DeMartini
Unfortunately the pre-87s have a kingpin rather than a ball joint so the djm stuff wonít work. Majour bummer.
Old 03-14-2019, 11:14 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Originally Posted by DeMartini View Post
Unfortunately the pre-87s have a kingpin rather than a ball joint so the djm stuff won’t work. Majour bummer.
Investigate that; my 81 F350 is ball joints, I seem to remember 1980 being the last year for kingpins....?
Old 03-15-2019, 12:32 AM
Kramercd's Avatar
Kramercd
Kramercd is online now
Kramercd is starting off with a positive reputation.
My '82 sales catalog states they introduced "lubed for life" ball joints in that year. I thought I read that in the repair manuals, but it may have been in the lmc catalog.
Old 03-15-2019, 01:09 AM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
Maybe that applied to F100/150's? My '83 F250 has kingpins
Old 03-15-2019, 07:31 AM
1986F150six
1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Hello, Ken!
Old 03-15-2019, 08:19 AM
DeMartini
Yes, I should have been more specific. The 250/350s had kingpins still.
Old 03-15-2019, 10:00 AM
Franklin2's Avatar
Franklin2
I didn't know what the difference was. I do know the guys with the f100's who have the older axles that are not compatible with DJM's dropped beams, just go to the junkyard and get the later model axles out of a f150 and use the parts/spindles off those later axles along with the dropped beams and bolt them under their truck. I didn't know if you could do the same, and get what you need from a 87-up f250 2wd and then buy the dropped beams and bolt them in place. The DJM people may know if this is a viable option. That would keep your suspension f250 style all the way around, with the larger wheel bearings and brakes and matching wheel patterns.
Old 03-15-2019, 01:03 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
FuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to allFuzzFace2 is a name known to all
Both of my 81 F100 were king pin.
Now for DJM you may want to give them a call as the last I heard they were making the beams for the smaller king pin.
Do they even make beams for the 250 / 350 trucks?
Now being you have a 250 I would guess you have the larger king pins like the F100's that have the 5x5.5 wheel pattern.
The 5x4.5 wheel pattern has the smaller king pins from what I have been able to search out between my 2 trucks.
The only other thing to do is swap in the newer ball joint front suspension with the DJM beams.
Dave ----
Old 03-15-2019, 01:18 PM
Franklin2's Avatar
Franklin2
They make them for 87-up f250/350 2wd.
Old 03-15-2019, 01:24 PM
FuzzFace2's Avatar
FuzzFace2
I never looked at them because I have the F100.
I am guessing they don't do the king pin ones because they would be the large ones. I wonder why they don't if the 250/350 both use the same large pins, again I have not looked into them other than for the 100/150 trucks.
Now that gets me thinking if the large pin 100/150 is the same for the 250/350 trucks and if so would the beams be the same?
Dave ----
edit: I checked with Auto Zone and the 86 F250 pins and the 81 F100 manual brakes (5x5.5 wheel) are the same part numbers for the king pins.
The F100 power brake (5x4.5 wheel) is the small king pins and not even listed for the F250.
Still wonder why DJM does not make beams for the king pin F250 as it only list 1 pin size and I think the beam might work on the F100/F150 large king pin trucks.
Old 03-15-2019, 09:31 PM
Ken Blythen
Originally Posted by 1986F150six View Post
Hello, Ken!
Hi there, David!
And Chris!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
