EGR valve part number? - Ford Truck Enthusiasts Forums
Old 03-14-2019, 04:32 PM
pepage
pepage is offline
pepage is starting off with a positive reputation.
Looking for the OEM part number for the EGR valve in my 1983 F250 HD 5.8L (W) E. Ford parts was no help and Standard Motor Products said they need a part number for the proper replacement valve. Can anyone help me?
Old 03-14-2019, 08:29 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
You need the Calibration Code, the label for which is probably long gone. You can look everything up in the books but it's going to take some work on your part.
Begin here: Calibration Info & Part #'s - Gary's Garagemahal (the Bullnose bible)
Old 03-14-2019, 10:20 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
vjsimone has a good reputation on FTE.vjsimone has a good reputation on FTE.
File Type: pdf
Old 03-15-2019, 07:12 PM
pepage
pepage is offline
Truck is A/T.
Thank you for the help. P/N was Motorcraft CX1182 and replacement part is Standard EGV229.
This is a great forum!
Old 03-15-2019, 09:38 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Thank you, Vinny.
Old 03-15-2019, 11:38 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
Originally Posted by ctubutis View Post
Thank you, Vinny.
Hello Chris!
Glad I could help...You snowed in out there?
Old 03-16-2019, 10:20 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
Originally Posted by vjsimone View Post
Hello Chris!
Yeah, I am in post bombo-genesis (or whatever they call it) mode, lots of clean-up of broken tree branches and what-have-you. The neighbors' gas meter popped off the supply line during the storm, but I never even lost electrical power and so never had it bad at all, it's just real wet outside now.
Old 03-19-2019, 05:43 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
For your records.
This may be your Calibration Page, but can't be positive.
What carb do you have ?
Old 03-20-2019, 11:55 AM
pepage
pepage is offline
Carb. label says: E3UE DA R(?) 2G 21
Old 03-20-2019, 12:06 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The original EGR valve has a sticker on it with the ID number, post what it is. Getting the part number is EZ, takes no time crossing the ID number over to the part number.
But if there's no sticker (they fall off), the Calibration Code is required because after 1979, there are no EGR valve application charts.
The carb ID number will not help identifying which EGR valve a truck has.
btw: Before y'all post specs, be aware that the OP lives in CA
Pic: 1983 F150/350 351W Calibration Codes. Happy hunting!
Old 03-20-2019, 02:36 PM
pepage
pepage is offline
Bill,
My post was to answer a question asked by Vinny. I will add what you sent me to my file. Truck was purchased used and I understand it came from Texas and was modified to pass CA smog check. Thanks for the help.
Old 03-20-2019, 04:41 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
Can you post a close-up of this Tag when you get a chance....
Does your truck still have a Mfr. Label in the Driver's side Pillar area ?
Bill, I am comparing his Carb to the Calibration Page I found.....
I did realize he was in Cali, but now curious of his built location.
Old 03-20-2019, 08:26 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
That's a twist, but from what I cipher, the EGR-V seems to be the same for a Cali & Non-Cali 351.
No EGR shows up on the routing diagram, but the parts list had the same numbers.
Look at the difference for a non Cali Cal (Canada maybe), 1/2 the stuff... Compared to the Cali Cal I posted previously.
Old 03-20-2019, 08:57 PM
matthewq4b
matthewq4b is online now
matthewq4b is a name known to allmatthewq4b is a name known to allmatthewq4b is a name known to allmatthewq4b is a name known to allmatthewq4b is a name known to allmatthewq4b is a name known to all
That is a Canadian calibration and very very common one to boot I recognized it right away
Old 03-20-2019, 09:43 PM
vjsimone's Avatar
vjsimone
vjsimone is offline
Old-Timer
One last question, & I'll leave you alone; What Venturi # is on the drivers side of the Carb fuel bowl?
Sometimes it is hidden behind the accelerator pump rod...
No rush, just the next time you are under the hood.... thanks.
Number = CFM
.98 = 190
1.01 = 240
1.02 = 245
1.08 = 287
1.14 = 300
1.21 = 351
1.23 = 356
1.33 = 424
These numbers are courtesy thrillseeker.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
