Wiring diagram for 1969 f100 ranger 390 three on the tree with Overdrive - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Reload this Page >
Old 03-13-2019, 06:41 PM
Jessica Hogan
Jessica Hogan is offline
Jessica Hogan is starting off with a positive reputation.
I'm need a diagram of the steering column wiring please ! This is a 2wd full size ranger
Old 03-13-2019, 08:17 PM
FECruzer69
FECruzer69 is offline
FECruzer69 is starting off with a positive reputation.
This hopefully will help you.
http://fordification.com/tech/wiring...9overdrive.jpg
My truck had the same set up.
Old 03-15-2019, 06:49 PM
FECruzer69
Oops! My bad. I just noticed that you wanted the column wiring. The wiring for the columns in the trucks with OD isn't different from other '69s with non-overdrive manual transmissions.
http://fordification.com/tech/wiring...ghts_81-85.jpg
The wiring for turn signals and horn is included here. I couldn't find one that just showed the column by itself.
Old 03-15-2019, 10:32 PM
Kurttb1
Kurttb1 is online now
Kurttb1 is gaining momentum as a positive member of FTE.
Anyone have a brief explanation of what the overdrive does and how it works?
Borg Warner Overdrive Transmissions explained LINK
Last edited by Kurttb1; 03-15-2019 at 11:07 PM. Reason: Found an Article on Overdrive tranny's
Old 03-16-2019, 07:55 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1969 F100 390 3 M/T with O/D
Originally Posted by Jessica Hogan View Post
I'm need a diagram of the steering column wiring.
The only wiring in the steering column is the T/S switch. It has nothing to do with the Overdrive (O/D).
The O/D is controlled by a cable that mounts to a bracket that's located under the dash to the left of the steering column.
O/D relay mounted on the firewall behind the carb, O/D kickdown switch located behind the accelerator pedal.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
