Timbren SES
I had Timbrens on my 2015 F350 CCLB 6.2 dually. I used them in conjunction with Torklift upper and lower stable loads when I was hauling my heavy Arctic Fox slide-in camper. They worked well for me and helped stabilize the heavy load without allowing the springs to overload. I really liked them since they were simple and failsafe since there were no air bladders, hoses, compressors, or fittings to fail. Unlike air bags they aren't adjustable but I didn't need adjustability just the additional spring support.
I have them on my ‘17 F350 and they work really well. I did swap the Aeon springs (the rubber part) for a shorter one to get my truck level while towing. The stock springs were slightly too tall. This swap also helped the unloaded ride as well. While towing my 5th wheel, the ride is much improved.
They are a good alternative to air bags, which I’ve had before. I like not having to worry about air pressure. Once you install these, you can forget all about them.
I have had timbrens or Firestone airbags on all my trucks..from tundra to my current f350...I'm currently running the timbrens on my f350 and love em...no worrying about adjusting the bags manually..or if u get the air tank w remote worrying about electrical parts going bad over time. And of course leaks which I've experienced...but not too say air bags are bad..alot of people run em n have no issues..but timbrens are install and forget. No moving parts to worry about going bad . The only downside to timbrens is if you hit a big bump you will feel the timbrens..but during reg driving you won't feel them at all..I tow a 5th wheel n the timbrens support my rear n level out my truck perfectly.
I have run timbrens on a F150 and my 2017 F250. They worked great and performed well. I like the simplicity of the system. The set I had came with different spacers so that I could dial in the bump height to fit perfectly for my needs. In fact I kept/used the same set from the F150 on the 2017 F250.
I didn't bother with them on the 2017 because the truck has the factory helper springs. I haven't had a load or a trailer heavy enough to even engage those in a year & a half of ownership.
Looks like I am going to give the only negative feedback on these. I had them on my 2011 F350 and they worked great when the truck camper was on. When the camper was off, which was most of the time, they rode extremely rough and my back just couldn't take it. On my install there was about 1/2" free space between theTimbren's and the stop so virtually every bump caused an abrupt jolt when the Timbren's bottomed out.
Gary
Gary
Gary
Gary
I wish timbrens came up w a system where u can install the bracket but the rubber bumb stop was removeable n interchangeable. Meaning I wish I could slide a shorter rubber bump stop onto their bracket n lock it in place when not towing..and when towing..I can slide on a taller bump stop. Now that would be awesome
Where did you get the shorter Aeon springs and do you have a part number? I would like some shorter ones for mine.
