2000 f350 4x4 srw need front axle help
I had a vibration with my hubs locked in thought ok u joint in the left axle Shaft. Re did other side 6 no ago. I had the new hub assy so I wanted to do hub assy u joint and brakes while I had it apart. After hub assy removal I noticed a lot of play on outer end of inner shaft. I can't find a good exploded view to see if there is something flat out missing or do I have other issues too?
outer end of the inner shaft will have a lot of play, it is supported at the differential only,the outer shaft supports the outer end of the inner shaft through the u-joint which has to have the play to minimize binding when steered, the outer shaft rides in a needle bearing in the hub/bearing assembly to keep it all centered.
colt1221
12-15-2012 09:43 AM
