Rebuilding questions on 302w
Old 03-13-2019, 05:50 PM
Deaf Wrencher
Deaf Wrencher is offline
Deaf Wrencher is starting off with a positive reputation.
Hello, I'm new at this website forum, so here goes: I have a 1977 Ford F150 Ranger Xlt 2WD that has the original 302W engine, C4 automatic tranny, and 9" rear axle. Now it has been sitting for several years since my dear old ma towed it from Arizona to WV. She wanted to rebuild/recondition the truck but never had the time to. So, I wanted to surprise her. It has only 29588.8 miles on the odo. The first thing I wondered is the engine itself, if I should replace all parts as original or upgrade to a better parts like Edelbrock carb 500 cfm ( she prefers Edelbrock over Holly) Edelbrock performer intake manifold, Edelbrock valve gaskets, aluminium radiator, Edelbrock water pump, DUI distributor, hedman headers, flowmaster exhaust, powermaster 140 or 200 amp alternator, powermaster starter (OEM or a step up from OEM). I do t know if I should upgrade to serpentine belt or leave it as a v belt (it got 3 drive belts). To my surprise, I found another 302W engine block sitting in storage for a long time that just needed to be de-rusted and cleaned. No cracks wherever. The casting shows D2OE-6015-AB, 2E19, which means it's a 1972 block for Ford Torino/Fairlane, 2-bolt Mains. The casting block on the truck is D4DE-6015-AA, which is a 1974 block 2-bolt mains. I thought I would use the 1972 block to try it on the truck with the upgrades and see what happens. I also came across 2 boxes for the engine that's been sitting in the storage garage. The first box is a Roadrunner MRC Engine Master kit #M5077, dated 1993. In it has: McCord Gaskets #95-1176, Clevite Timing Chain #3004, Fel-Pro Sealer Set #EIS 70, Sealed Power Quality Piston Ring Set #E-251X .030, Pioneer short block plugs # PE-108-R, Rear Main Bearing split seal # P017015, Roller tappets (I think) # 16-HL1900, Dura-Bond Precision camshaft bearings #F-18, L&B Engine parts oil pump #6-25, Melling automotive products #IS-68, Roadrunner reground camshaft MRC #53-7575, Silv-O-Lite 8 cylinder heads #8-1157 +.030. The second box has a crankshaft from Roadrunner MRC forged stock #C5468, forging #2M, Michigan77 mains #MS-590 P-30 and Michigan77 rods #CB-634P.030. it was for a bore size .030. some of the metal parts has a little rust on them. I thought I could use both boxes after I clean up the rusts. What's your take on these?
Old 03-13-2019, 06:42 PM
lafermedavid
lafermedavid is online now
lafermedavid is gaining momentum as a positive member of FTE.lafermedavid is gaining momentum as a positive member of FTE.
sounds like you have a plan ,I had the same truck with 32,000 miles on it back then ,and drove it for over 200000 miles before a rebuild,I actually still own the motor,and its fresh sitting on a stand,out of the weather,just nothing to put it in,,,,your Mom sounds tough,,welcome
Old 03-14-2019, 04:51 PM
Deaf Wrencher
Thank you, lafermedavid. I just wanted to know everyone's take is on this subject. The master kit was in storage since 1993, Alo g with the forged crankshaft. I haven't even heard of most of the brands, except sealed power and Fel-Pro. I really haven't decided on replacing with OEM or upgrade with the master kit and Edelbrock stuff
Old 03-15-2019, 01:06 PM
kettle-one
kettle-one is offline
kettle-one is starting off with a positive reputation.
If it has roller tappets then the kit is likely for a 86-95 5.0L engine. The rings should be metric thickness if it's 5.0 kit.
Old 03-15-2019, 06:39 PM
Deaf Wrencher
Here's a pic of those parts of what I think is tappets. Could be a flat tappet.
Flat Tappets?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
