Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Chasing an Oil Leak 2012 F-250 6.7
Old 03-13-2019, 03:41 PM
FSFT
FSFT is offline
FSFT is starting off with a positive reputation.
105K on 2012 6.7 SD. After the truck sits for a couple of days, Ill get a couple of oil spots on the ground. Crawled underneath the drivers side to find the fwd yoke covered in oil. Oil is coming down the back of the engine on the drivers side. Have poked around up top and can't find the source. Attached is a picture as I am shooting straight up the back side of the engine on the drivers side. There is a small oil pooled as well on the aluminum square piece up top too
Any ideas where I should look?
Thanks
Old 03-13-2019, 04:20 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
Deleted...
Old 03-13-2019, 05:12 PM
FSFT
FSFT is offline
I think you mean transmission, not engine. Regardless, I agree, looks like a royal PIA and $$$$$
Old 03-13-2019, 10:39 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
m-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputationm-chan68 has a superb reputation
Turbo oil line fitting?
Old 03-14-2019, 12:19 AM
senix's Avatar
senix
senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I would check the valley of the motor with a flash light. Concentrate on the turbo lines.
Old 03-16-2019, 03:03 PM
20fordmastertech18
20fordmastertech18 is offline
20fordmastertech18 is starting off with a positive reputation.
The oil separator is right above that. I would look closely at the two spots it mounts to the balance cover and see if itís running from there.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
