Front axle driving me crazy
Just asking because so many have been swapped out to aftermarket, but kept the original springs installed.
Just in case it's not the lockout mechanism making the noise, you could test the drive shaft by removing it and seeing if the noise remains.
You can also rotate the tires front to rear, because sometimes wheels flex and make squeaking noise. Are you running steel wheels, or aluminum? If steel, do you have hubcaps/wheel covers?
With the wheel bearings, were they replaced, or just re-packed and adjusted? And either way, were they adjusted using the specific factory method?
Paul
I believe they are the original Ford lockers,
Was hopeful I would not need to go that far, I pilled one spindle and it was tough.
Steel wheels, no hub caps
I used the factory method, I believe. Torqued to 50 ft/lbs, while turning the hub, backed off a quarter turn then set the locking plate and nut
The stock ***** were a chrome cap with red plastic (now likely faded to pink) **** with the FORD name molded in.
The light duty ones looked just like a Bronco/F150 hub, while the heavy duty ones were either larger in diameter but looked the same, or maybe one other style. The old "external" hub should have gone away with the early '77 High Boy setup I think.
Driveshaft removal is the easiest test of all practically. No more messing with the bearings or spindles. And yes, they're tough to get out! Congratulations on even the one successful removal!
I've seen (heard) many steel wheels squeak over the years. Doesn't happen all the time luckily, but it's not that uncommon either.
I've seen ranges (even in Ford books) of from 70lbs to 150lbs for the outer locking nut. I use 100lbs as a safe setting, but for many years used 75 as my final torque and never had an issue. Not sure what the 44 on the F250's gets though, in case it's different.
The bottom line is you do need that final torque to pull things tight, and to keep it tight for the duration of it's service until the next re-pack.
But even with all that, if it was the old bearings squeaking and you put them back in, your squeak would not go away necessarily.
I don't think I've personally run into a squeaky bearing actually, but have heard of them and know it could happen. Just that there are other, more likely culprits at this point still.
Good luck.
Paul
Back to the front axle shafts though, you said you had a spindle off? Did you check the axle shaft u-joints while you were in there? While they do not make noise when in 2-wheel drive (because they're not spinning) a hub that is locked, or a transfer case that is shifted into 4-wheel drive could cause them to turn and make noise if the u-joints are toast.
The diff won't make that noise in two-wheel, but a transfer case or transmission can, and so can springs and their bushings, ball joints, and any number of other things.
Try this... Spray the front leaf springs down with water from a hose for a minute so that water is in-between all the leaves (just two on each side in your case?) and then drive it.
If the squeak went away, it's just the leaves rubbing on each other. Sorry I forgot to mention that other possibility. Ran into that myself.
Although, leaf squeaks might get more prominent with speed, but they don't change their frequency with speed. Only a spinning part will do that. So ball-joints, leaf springs, frame members and joints, will all sound similar at low or high speed. A wheel, bearing, u-joint etc. will change with speed.
Paul
I "fixed" it by rigging up some polyethylene rectangles (cut out of a big Clorox bleach bottle) at all contact points between individual leaves. There wasn't as easy access at the time to the Teflon, or poly pads that are everywhere today. So I made my own.
Worked like a charm for a few months at a time, but would eventually just deteriorate as you can imagine.
Paul
They often spin while driving just due to hydraulic friction of the gear lube, but that's it. If you can spin the driveshaft easily by hand then it's fully unlocked. If that's the case, then it "should not" be the squeak. Even if it's spinning due to friction, it will not fully keep pace with the vehicle speed.
But it's not uncommon for a hub to lock and not unlock. Especially if the spring is suspect.
There should be zero wear on the spring cups under normal conditions. I've personally never seen one with any sign of wear and tear on it, even after hundreds of thousands of miles.
Normally the spring does not spin against either the cup or the inner dog gear. What kind of wear, or damage did you find on the cups? And are the new ones already showing signs of wear? If so, something is wrong and there is likely the source of your squeak too.
Paul
I've not often thought of just what moves and when, but I believe it's simply there to protect the spring and the bearing from each other in the situations where that particular piece moves.
For some reason, Ford/Dana decided that they didn't need them on the Dana 60's and I've only seen them on the 44's and 30's.
How did the backside of the spring look?
The spring moves with the hub, but some parts of the bearings can move independently. Obviously the races/cups themselves are stationary, as they're pressed into the bearing hub.
The inner and outer bearings still have an "inner race" that is part of the bearing/cone assembly. Perhaps it's that inner race that is moving? Did your spindles show any sign of brinelling or scoring, or burning? Discolored and/or scratched and/or worn in other words?
It's not exactly a press fit, but it's not supposed to spin freely once the bearings are adjusted either. Free spinning of the inner races of a tapered roller bearing means that either the bearing rollers are catching on the race and causing it to spin, or the spindle and/or race are so worn as to be too loose of a fit.
Seen it happen, but never heard it happen. But that kind of improper action could certainly cause a squeak.
Hate to say it, but even with just the noise it would be worth a deeper look. The fact that you already found wear on an adjacent part means it's definitely time to dig back in there.
Paul
And in one or two cases, the spring would not fit into the cup anyway. Which, for me at least, just cemented the deal.
Do your springs both fit into the cup if the lip is turned towards the spring?
I can't say I've heard or read a definitive description. But I've been putting cup-over-bearing for almost 50 years now and never had a single issue with either bearing or hub mechanism. Knock on wood!
I wonder if the bearing cage is moving when it's not supposed to? Such as if the rollers were catching on it and causing it to spin under the spring seat. I don't have a set here to compare, but I believe the spring seat is contacting the roller cage. So in theory then, if that's true then the only way for the spring seat to wear would be if either the cage and seat are spinning against each other, or the seat is catching on the cage and causing the seat and spring to spin against each other.
I forgot if you said, but which side of the seat is showing the wear? The side against the spring, or the side against the bearing?
Paul
