Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
What are these wheels called?
Old 03-12-2019, 02:38 PM
mrstang01
mrstang01 is offline
mrstang01 is starting off with a positive reputation.
What are these called (currently on a 78 F700 I'm looking at), and are they upgradeable to a newer style without spending an arm and a leg?
Old 03-12-2019, 02:47 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
truckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant futuretruckdog62563 has a brilliant future
It’s a Dayton style spoke wheel with demountable outer rim. In this case the rim is a locking side ring style, one of several styles made by Goodyear. The 20” locking side ring rims and tires can be replaced if you wish with modern 22.5” tubeless demountable rims and tires. Stu
Old 03-12-2019, 03:38 PM
mrstang01
Where's the best/cheapest place to pick those 22.5's up?
Old 03-12-2019, 03:47 PM
truckdog62563
Find a local big truck yard to buy used 22.5” rims, then you might even find good used tires at a service place that has the contract for your local school buses. The 22.5” rims come in widths 6.75”, 7.50”, and 8.25”. Get ones that are close in width to your original 20” tube types. Stu
Old 03-12-2019, 03:50 PM
mrstang01
So 22.5 Dayton style wheels, just without the split ring?
Old 03-12-2019, 04:03 PM
truckdog62563
Yup. The tubeless one piece 22.5” rim has the same 28 mounting angle on the spoked spider as the old 20” tube type. You can look at them in the below Accuride and Hayes-Lemmerz catalogs. Stu
https://www.accuridewheelendsolution...ct-Catalog.pdf
http://www.dsuban.com/website_docs/H...alog_02-03.pdf
Old 03-12-2019, 04:10 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
The Dayton style wheels are still heavily used. They are on almost every intermodal trailer. The wheels should be easy to get.
Old 03-13-2019, 02:22 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
Shiftoholic
Freightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud of
Hit any truck tire shop. Should be able to get used rims easily. It was 17 yrs ago, but I bought them $50/ea and they were blasted and painted. Back then 22.5" Toyo radials were $250 each. Now they are double that.
Be hard pressed to find someone that wants to work on the old split rims! That is a dying art(literally).
Old 03-16-2019, 06:34 PM
1979 Ford's Avatar
1979 Ford
1979 Ford is offline
1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold1979 Ford is a splendid one to behold
I call those Minnesota mags.
Old 03-20-2019, 02:29 PM
Freightrain
Shiftoholic
"Wobble Wheels" (that is if you don't get them torqued on straight). You have to lay a hammer down next to the wheel, spin wheel and tighten the lugs evenly til there is minimal/no run out. Then torque them.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
