Itís been done - gooseneck on bumper pull
Old 03-11-2019, 09:07 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
so I bought a 2019 f-450 with the prep kit and I have the ball kit .....but with a 28k weight limit on the 3Ē recover and adjustable height 3Ē hitches that can handle 32k lbs it makes me think the bed mounted gooseneck might become a thing of the past.
i googled it and found folks who are in fact pulling gooseneck trailers with their bumper hitches.
what do you folks think?
Old 03-11-2019, 09:22 PM
ATC_F350's Avatar
ATC_F350
ATC_F350 is offline
ATC_F350 is starting off with a positive reputation.
Goosenecks pull so much nicer than a bumper pull, I seriously doubt they'll go away in any significant numbers.
Old 03-11-2019, 10:41 PM
'65Ford
'65Ford is offline
'65Ford is gaining momentum as a positive member of FTE.
A goose neck may fit a ball on the bumper but I can't imagine anyone doing that for any reason. You'd need something like a medium duty dump truck to keep that heavy of a goose neck stable. It would defeat the purpose of a goose neck...excellent stability with heavy trailers.
Old 03-12-2019, 07:19 AM
wrvond's Avatar
wrvond
wrvond is offline
wrvond has a great reputation on FTE.wrvond has a great reputation on FTE.wrvond has a great reputation on FTE.wrvond has a great reputation on FTE.
Moving the weight from over the axle to the bumper is going to move more weight off the front axle, which (probably) will adversely affect handling. The extensions required to get the ball up higher or the pin down lower would surely weaken the overall design of the gooseneck as well, I would think.
By moving the gooseneck trailer to the bumper, you are giving up all the advantages of a 5er/gn and taking on all the disadvantages of a travel trailer. With the higher pin weights inherent in GN's, how would you incorporate a WDH on one attached at the bumper?
Old 03-12-2019, 08:57 AM
brickman
brickman is offline
brickman is gaining momentum as a positive member of FTE.brickman is gaining momentum as a positive member of FTE.
I think it’s a terrible idea....
Old 03-12-2019, 09:02 AM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.
+1 on the terrible idea. Just because you can do it, doesn't mean you should. It's going to lighten the front axle tremendously and since you have no WDH there's no way to transfer that weight back.
Old 03-12-2019, 10:07 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
3" is rated for 21k not 28k I believe for 2019.
Old 03-12-2019, 10:32 AM
HRTKD's Avatar
HRTKD
HRTKD is offline
That is correct. The bumper pull rating is 21K for the DRW depending on configuration. The Ford towing guide does specify different ratings for WDH and non-WDH as well as engine and axle ratio. so it isn't 21K for every DRW you find on the lot.
See page 24 for more info.
https://www.fleet.ford.com/resources...de_r6_Nov8.pdf
Old 03-12-2019, 09:08 PM
99150's Avatar
99150
99150 is offline
99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation
Just because a person *CAN* do something does not mean they *SHOULD*!!!!!!
Happened at Loves truck stop @ Williston, ND during the peak of the oil boom!!!!!!!!
Old 03-13-2019, 10:34 AM
ford390gashog
Old 03-13-2019, 10:43 AM
HRTKD's Avatar
HRTKD
HRTKD is offline
Right. Let's add even MORE complexity to a subject that the average layman can't explain.
Can I get one of those for my Nissan Leaf so I can use it to tow my toy hauler?
Old 03-13-2019, 10:51 AM
ford390gashog
Sure you can
Old 03-13-2019, 10:52 AM
ATC_F350's Avatar
ATC_F350
ATC_F350 is offline
With that light rear end, I bet that was a scary as h#$l ride.
Old 04-21-2019, 12:22 PM
Brandonpdx
Brandonpdx is offline
Brandonpdx is starting off with a positive reputation.
Those converter dollies are kind of cool but they probably want big bucks for one. It also looks like you have to use the their specific receiver hitch with it
Old 04-24-2019, 05:01 PM
2009kr
2009kr is offline
2009kr is gaining momentum as a positive member of FTE.2009kr is gaining momentum as a positive member of FTE.
Max weight on the back hitch is 2100#. That's a pretty small gooseneck trailer.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
