63 F-100 restiration
Word to the wise - this era of pickup, the hood latch and safety catch assembly probably need some attention by now. Anyone who has had the hood fly up at highway speed knows what I am talking about. I managed to attain the much coveted "Flying Hood" award with oak leaf cluster, signifying middle of the night in complete darkness operations. Make sure the alignment is good, everything is clean and lubed, and the safety catch lever releases smartly into the pocket.
Also clean out the heater box, the 2 speed heater blower uses a large, naked wire-round resistor to drop the voltage for low speed and it gets red hot. Unfortunately it is located in the air stream for cooling purposes, right where leaves and pine needles, and maybe a mouse nest &c and debris accumulate. Several trucks have been completely consumed by fire this way.
A fire extinguisher is strongly advised when working and operating vintage cars and trucks, as fuel hoses and other components are worked on, replaced and repetitive troubleshooting can lead to unexpected surprises.
In the pics the dash wiring hanging down like spaghetti is shown to be less than stellar. No telling what kind of splices or other handiwork is involved. It is probably best to keep the battery negative terminal cable disconnected when not under your direct supervision until it can be sorted out.
Yes, it runs. I rebuilt the carburator and bought a new air cleaner, it didn't have one. The battery is new too, I also replaced the heater hose.
To me the word restoration means one thing - everything else is refurbishing, rehabilitating, modifying, etc. etc. But restoration as the dictionary states means only one thing. It would be what Skidoo could do if he put all of the engine pieces back on his truck that he kept. It would be putting everything back to the way it was originally.
Point being - sliding a crown vic suspension under it or lowering it 4" is not restoring the truck by definition. Just pointing out the idea behind the word restoration.
Chad
Chad
Chad
Chad
I bought a 92 Mustang that until late last year was my daily driver. I'm not interested in performing a restoration on it but don't necessarily want to strip it and not be able to drive it in the coming months/years either. It's in good enough shape to drive and enjoy but there are things that I want to/have been changing so in the spirit of that I've been making targeted changes as the opportunity arises for me to do so. The power steering didn't work when I bought it, I went in and fixed that and while I was there swapped all the bushings out for polyurethane and replaced ball joints, etc. Thought I blew a head gasket (which in retrospect I think was actually a leaking lower intake manifold gasket) but went ahead and pulled the motor to throw in some new gaskets and install a cam, different heads, etc. These projects have taken the car off the road for periods of time, but I will get it back on the road before too long. By chipping away at the stuff I want to make changes to a little at a time I can still enjoy the car and get it to where I ultimately want it which works for my goals with the car, I have another vehicle to drive while this one is down and the space to store it. If I were trying to build something with a million horsepower or whatever the case may be I might have to take a different approach. If I still needed to daily drive the car then pulling the motor to install performance parts not inherent to the operation of the vehicle as a vehicle isn't prudent.
I feel like that was all over the place but hopefully it helps a little. TL;DR decide what your goals are with the truck and come up with a realistic plan and start doing your research.
Chad
Chad
I want to restore it to mostly original, with exception of the steering, probably wheels, suspension (i want to at least have coil overs in the front), transmission, diff, change to disc breaks, new headliner, floor, and possibly (if it helps) fuel injection.
So basically, I want to restore it to looking factory on the outside and inside, but with some modern things to make it safer and more efficient.
And, be prepared to spend money, lots of money!
Well i know i can't get original, but I'm going to try to get a mostly original look with modern safety and some technology(if i do fuel injection). And yeah, lots of money is right, i know this is going to most likely years, but patients is key right now.
I want to restore it to mostly original, with exception of the steering, probably wheels, suspension (i want to at least have coil overs in the front), transmission, diff, change to disc breaks, new headlighner, floor, and possibly(if it helps) fuelijection. So bassicly, I want to restore it to looking factory on the outside and inside, but with some modern things to make it safer and more efficient.
I like the term "RestoMod", restoration is a specific term meaning restored as it was originally from factory. Nothing wrong at all with your plans but we see the term abused, often when trucks are for sale. A restored truck has the original type power plant, brakes, steering, suspension, transmission, interior, seats, paint color, markings and accessories &c.
Thanks for the good advice , I just got my 63 Mercury Last fall and defintely want it running through most of the recreation . Mine isn't original as it has a Buick 430 Motor and Auto Trans now , they came with it . Original was a 223 with a 4spd . I am suprised how well it rides off road , went a couple times through the winter , not to far though . Thanks
Dewdrop East of Kamloops BC
Kamloops Lake
Kamloops Lake
#28
NFLagent
07-03-2015 10:36 PM
4tl8ford
01-04-2008 11:43 PM
