C6 to 4spd top loader swap advice help me not to get ripped - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1967 - 1972 F-100 & Larger F-Series Trucks
Reload this Page >
Old 03-13-2019, 12:12 AM
SoCal69's Avatar
SoCal69
SoCal69 is offline
SoCal69 is starting off with a positive reputation.
Old 03-13-2019, 01:21 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
Shiftoholic
Freightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud of
A GV would likely be your best bet. Might be a bit more by itself but since you don't have to go through the whole clutch pedal conversion it will likely be cheaper and easier in the long run.
My experience with TKO's is it would survive just fine in daily driving a pickup. If you tried drag racing it, it would likely not last without the correct clutch(racing clutch). The shock load would take it's toll, and like most TKO's 3rd gear(weakest) would grenade.
I've run a 4 spd toploader in my '69 for 30 yrs, beat on it every time it's out. 428CJ/4spd/4.56 gears.
It too is a $50 for fuel to have fun one day kind of truck.
Old 03-13-2019, 01:48 PM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is online now
KubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to allKubotaOrange76 is a name known to all
Considered a dana 61 swap out of later model truck? 3.07 gears, i think it was prevalent in alot of 1st gen dodges with cummins.
Old 03-13-2019, 01:59 PM
SoCal69's Avatar
SoCal69
SoCal69 is offline
I appreciate a the replys reason why I mentioned top loader first instead of any other was it came in alot of Ford's and thinking that would be the best and easiest if I wanted to do a conversion hit the bone yards for the clutch pedals bell housing for a 390 from a Fairlane or mustang , I was going to mention that alot of muscle cars Ford's in the 67/68/69 70 era had 429/390/ mustang GT Fairlane GT that's alot of racing around stop light hits and burnouts , I can see towing something it wouldn't be a ideal choice but 250 is the badge bigger kingpins Dana 60 bounce omatic rear springs 8 lug A Gt mustang probably see more tourqe and abuse my truck ever will the cast iron external linkage top loader might be a option .
Old 03-13-2019, 02:01 PM
SoCal69's Avatar
SoCal69
SoCal69 is offline
Nice truck .....
Old 03-13-2019, 02:06 PM
SoCal69's Avatar
SoCal69
SoCal69 is offline
Yes I was reading up online alot of guys are having that issue in muscle cars with a Dana 60 since they only go as high as 3:54 there were some that came with a 3:31 hard to find though ... They mentioned the Dana ,61 ...I need to look more into the bone yards see if I can find one looking for my best option
Old 03-13-2019, 03:20 PM
RichS2659
RichS2659 is online now
RichS2659 is gaining momentum as a positive member of FTE.RichS2659 is gaining momentum as a positive member of FTE.
'80's Econoline 250/350's came with the D-61 as a source. I had a '82 Chateau 15 passenger van with one. You will have to move the spring pads inward due to the Econo's frame being wider.
Old 03-13-2019, 04:03 PM
KubotaOrange76
BE worth looking for, missed this one by a few years
https://www.ford-trucks.com/forums/1...h-carrier.html
Alot of 4x4 people out there looking to get rid of them, because lower gears are an issue with the offset of the carrier in the housing they used to get the high gears to work.
Old 03-13-2019, 06:54 PM
SoCal69's Avatar
SoCal69
SoCal69 is offline
Well crap .....math wasn't my favorite subject I just realized anything is a improvement over 3k rpm at a 70 mph cruise ,say 65 at 2,800 I was looking at the Spicer RPM calculation ....... but I thought it was thousnds I would drop it's hundreds
So even to put say 33 " tires it will drop maybe 450 max I thought it was thousands !!!!!I'm really off 65 at 2,400 is better than 2,800 70 at 2,500 I'm at 2,000 at 45 mph now ...
Old 03-13-2019, 06:59 PM
SoCal69's Avatar
SoCal69
SoCal69 is offline
Haha I bought headers and all this stuff looks nice but go over 80 mph watch the gauge go min by min too funny ...funny thing I liked the body style of the truck the 250 it had the C/S mirrors and all cargo box etc the auto indicator thing was broken when I bought it that says 1,2,D R P. O thought it was a 4spd .......
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
