Rebuilding front turn signals, running lights - Ford Truck Enthusiasts Forums
Old 03-10-2019, 06:17 PM
hillcountryflt's Avatar
hillcountryflt
hillcountryflt is offline
hillcountryflt is gaining momentum as a positive member of FTE.
I am working on swapping out the grill on my 71 with a painted one from a 68.
The bulb sockets on the turn signals are not in great shape. The bulb needs to me jostled some times to work.
will any double contact light socket kit do the job?
or is there any easier way. LMC does not show that assembly available for instance.
Old 03-10-2019, 06:28 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Upper pic: Ford only sold the park lamp body as an assembly: C7TZ-13200-E Right & C7TZ-13201-E Left = 1967/69 F100/350.
Both are obsolete, a source in SoCal has the right side, no one has the left side. Neither side on ebay.
Old 03-10-2019, 08:01 PM
lambchops25's Avatar
lambchops25
lambchops25 is offline
lambchops25 is starting off with a positive reputation.
Originally Posted by hillcountryflt View Post
...will any double contact light socket kit do the job?...
I would think as long as your not hung up on 100% factory original, and you don't mind possibly having to modify the original a little bit, (I don't know if you have to or not), Then I would think you could use a double contact light socket kit.
Old 03-10-2019, 09:09 PM
F100 '64's Avatar
F100 '64
F100 '64 is offline
F100 '64 is starting off with a positive reputation.
I bought replacement sockets from Mac's. They worked out pretty good. Below is my YouTube video covering it...
Good luck, Pat
Old 03-11-2019, 07:05 AM
hillcountryflt
Not much worried about OEM, just functionality. Don't have the time, money or inclination to make "Forever Project" an all original truck.
Double Contact Sockets
F100'64 thanks for that lead. Even though they show as rear sockets, i see no reason they won't work in the front.
How difficult would it be to get the old one's out. Not sure how the are attached.
I do see some options of leaving the original socket housing in and simply replacing the contacts/wire.
RepairKit
Old 03-11-2019, 07:43 AM
F100 '64's Avatar
F100 '64
F100 '64 is offline
RepairKit
You should watch my video that I linked. I used them in the front and rear. They came out fairly easy with a twist, I did solder them in place because the new ones were not as snug. I'm glad I used solder over JB Weld because if I ever need to replace them again I will be able to remove them.
Pat
Old 03-11-2019, 08:07 AM
hillcountryflt
Pat
I am work, so had to watch with audio off. But did make it look pretty simple.
Old 03-13-2019, 12:25 PM
hillcountryflt
Pat
Well I tried rebuilding an existing socket last night with a kit from NAPA. Did not go well. It would not compress enough to get light bulb in. So I ordered one of these double contact light socket to try. There were a variety of different part numbers for this item.
Old 03-13-2019, 12:56 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
Shiftoholic
Freightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud of
Try something like this? Just have to make the hole bigger.
https://www.autozone.com/electrical-...ket/803353_0_0
I think this is a twist style:
https://www.autozone.com/electrical-...ket/438919_0_0
Easy to replace if they ever get messed up from moisture.
I didn't find the one that takes the newer 3157 style bulb with the plastic post instead of metal(less corrosion possibility)
Old 03-13-2019, 01:28 PM
hillcountryflt
That last one with three wires. I am guessing the third wire is for ground since the unit is plastic. Interesting looking.
Old 03-13-2019, 01:57 PM
Freightrain
Shiftoholic
Yes, third wire should be ground.
I recall Autozone having quite a selection of plugs in their electrical aisle. Might be able to find something you can retrofit.
I can remember dealing with my 1970 F100 back in the 80's and trying to keep the front signal working reliably.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
