o2 oxygen senor / sensor heater no ready
Hi All,
I have a 2007 v10 2v with 120k miles. It's a Glaval shuttle conversion that I'm trying to turn into a camper. But first...I need to get it smoged in CA. I first had some trouble codes for the 1 and 6 cyclinders misfiring but those have been resolved with new sparks plugs and replacing some bad fuel injectors. The shop that did my fuel injectors also ran it on a Dyno for me to try and get the drive cycle done. I hope they did it per the Ford spec, but the cycle would not complete. They recommended replacing all 3 o2 sensors and quoted $700, so I did the work myself. I finished that today and drove the vehicle about 50 miles, but did not use the drive cycle testing procedure. I monitored during driving and saw bank 1 and 2 upstream sensors were about 0.2v - 0.8v and the downstream sensor, after the cat, was a minimum of 0.3v and max of 0.7v
I'm not sure what I should be looking for on voltage for the downstream sensor. My plan is to do the drive cycle per the specs tomorrow. Are these published by Ford? Any other opinions on what I could check for? Maybe my catalytic converter needs replacement? Or I've ready some notes about a fuse related to the computer.
Thanks for any input here!
I just went through the same bull, if your truck is only OBD 1 compliant (as shown under the hood on a sticker) they will never be ready to test because the truck is not California complaint, only "federal". In Pennsylvania, I had to get a Dyno test done, I do not know what California does. If you want me to I will go take a picture of the sticker under the hood
No check engine light, no active codes. GVWR is 11500 LB but I think CA has some different rules so it doesn't meet any threshold.
https://www.dmv.ca.gov/portal/dmv/de...smogfaq#BM2535
It's OBD2 compliant per the sticker under the hood.
Just drive it normally for a few days, if you can. That should allow the rest of the monitors to run to completion and either pass or fail. Your O2 sensor readings appear to be indicating normally operating sensors. If you want to see if the cat is actually doing it's job, you'd need to set up Torque Pro to graph the three O2 sensors while you drive.
I did look up the drive cycle information, The drive cycle I used today is published by prodemand.com looks like Snap-On owns that.
I'm still getting incomplete for these monitors.
I logged some drive data from the OBDII today. I've uploaded it into Google Docs if anyone is interested in taking a look:
https://docs.google.com/spreadsheets...it?usp=sharing
I highlighted the o2 sensor readings. I'm concerned about "<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->Short term fuel trim (Bank 1 Sensor 2) (%)" column AP.
When this vehicle was previously in for repair they had cleaned and replaced some of the fuel injectors, but only did one side. I'm wondering if this is a faulty reading, not related, or perhaps I need to have my fuel injectors on the other bank inspected.
Thanks for any help.
-Andrew
-Andrew
Looking at the data, I'm concerned about the voltages in the post cat o2 sensor (Bank 1 Sensor 2)
I'm reading that the voltage should be between .5 and .7v
https://www.autoserviceprofessional....agnosis?Page=2
I'm more suspect of my catalytic converter at this point. Does anyone have an opinion on this or a recommendation on how to test the Cat further? Looking at around $500 in parts to replace.
The downstream sensor can swing just as much as the upstream (.1 to .9 V, generally) The key is that it must switch at a (required) lower rate if the converter is functioning.
Set up a graph of the two upstream sensors and the single downstream sensor in Torque. If the cat is not functional, the downstream sensor's waveform will look almost like the upstreams. If the cat is working, the downstream will switch far fewer times and spend a lot more time in a relatively steady state or without quite the rail-to-rail changes in amplitude, depending on throttle behavior.
frankhamil
Escape & Escape Hybrid
05-27-2022 01:23 PM
Barbeast
Modular V10 (6.8l)
28
01-21-2018 08:28 PM
97ExplorerEB
07-26-2007 08:50 PM
