Carb shooting mist..no start - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 03-10-2019, 10:34 AM
3000gtman
3000gtman is offline
3000gtman is starting off with a positive reputation.
I'm headed to her now...2hr drive. Will be changing oil and plugs and checking tdc again and compression again
  #32
Old 03-10-2019, 11:15 AM
3000gtman
On a different note can someone send me a pic of the springs on carb for the throttle So I can see where to hook mine up at
  #33
Old 03-10-2019, 01:47 PM
3000gtman
So I removed number 1 plug...put paper in hole...rotated engine by hand...the paper popped out roughly between spark plug on dist 2 between 6...however the piston in cylinder 1 is all way down. .I put paper back and kept rotating by hand..and I got a softer pop noise paper flew out exactly right by number 1 spark plug on dist. And the piston is all the way up in cylinder 1.
  #34
Old 03-10-2019, 04:36 PM
3000gtman
ITS ALIVE!!!!!!!!!!!!!!!!! I GAVE IN and kept trying the tdc...yall were right...she was 180 out...I swore it was right but wasnt...I was worried to pull dist and have the oil shaft fall again. However it didnt!! I moved the rotor to spark plug 1 and reinstalled dist...she fired right up. Needs to be tuned and timed. But it's a start. I thank each and every one of yall for the help. I'll still be asking for help Like I need good pics of return springs for the throttle. Oh and guess what...she has oil pressure on the original dash cluster!!!!!!!
  #35
Old 03-10-2019, 09:37 PM
TenaciousT
TenaciousT is offline
TenaciousT is starting off with a positive reputation.
I have to laugh at all the resto-mod shows on TV . They go to all the work of rebuilding or new engine and it never starts . But after a while someone puts the dist. in the right way and it runs perfect !
  #36
Old 03-11-2019, 12:12 AM
wauto
wauto is online now
wauto is starting off with a positive reputation.
Glad you got it running !
  #37
Old 03-11-2019, 06:59 AM
3000gtman
I really thought I had it right but things happen. She runs now tho. Hopefully stays that way.
  #38
Old 03-12-2019, 04:10 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
Good to hear!
  #39
Old 03-13-2019, 09:26 AM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
MIKES 68 F100 has a very good reputation on FTE.MIKES 68 F100 has a very good reputation on FTE.MIKES 68 F100 has a very good reputation on FTE.
When I rebuilt carb I didnt set bowl level. I'm not sure what that even means. I just replaced parts that came in the kit. Maybe shes getting to much fuel? I'm not sure
start here , YOU NEED TO SET THE FLOAT LEVEL .
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
