62 F250/F350 4x4 Wheel size
New to this forum. I soon am going to be working on a 62 F250 4x4. I can't access this truck right now but I need to find out what size single piece wheel will replace the split rims on this truck for a stock look. Also tips on where to buy them would be great! Thanks
F350 used a 6-lug wheel so quite a bit different than an F250.
Are you looking for the 16" x 6" wheels? I have about 15 of those wheels (5 each for 3 trucks includes spare). Bought all but 4 of them from AKH Wheels in Ellensburg, WA. He has a web site and shows 2 of these wheels available right now.
AKH Vintage Wheels - Ellensburg Washington
Chad
Chad
You'd probably want to make sure of the series of truck before buying any wheels. AHKWheels wants $175 per wheel last I checked, plus shipping if required.
The F250 was available from the factory in a 4x4 in 1962, but the F350 was not. It could be a conversion of some sort, but if it is a factory 4x4 then it should be an F250.
The F250 bolt pattern is 8 lug on 6 1/2" spread. Center hub hole is approximately 4 3/4" diameter.
Chad
Chad
James_Western_Canada
07-17-2016 10:01 AM
fordf350camper
03-11-2010 06:52 AM
unrealtrip
02-05-2010 11:55 PM
