Ford replacing 2018 5.0s?
#107
#108
I hope it gives you many trouble free miles and years of service.
#110
Congratulations! Bright side if they didn't pull the cab I can almost guarantee they had a well trained tech on the job. There is a way to skip the ford steps and still bill all the hours just risky and requires some finesse and not having to pull the cab is a plus for the owner.
#111
Personal recommendation - don't baby it. Get fluids up to temp and hit 3/4 throttle and get the revs up. Try and avoid short trips or highway at one RPM. If you must do highway, vary RPMs even if you need to lock out upper gears (what I did on my ride home from NH to pick it up)
#112
#113
#114
#115
#117
Thank you, Sir! I ran it a bit today. It’s tight. I see the parts reclaimed from my last engine, but other than the scratched and deformed heads of the plastic drive rivets holding the shroud behind the grille, it looks untouched. I just hope it is a chapter now closed. I’ll remain positive, but the first time I pull the dipstick and see it 1/2 quart low, I’ll probably fall over.
#118
Well, an update the new mill.
Runs good. Checked oil last night. With 800 miles in it, it’s down about 1/2 a quart. I know it’s probably normal for the first few thousand, but I hope it stops. That quantity won’t be acceptable if it continues. My last mill wouldn’t burn an ounce before 1200 miles.
#119
I'm at 1300 miles total, used a quart so far and just topped off. I've been doing at least 1 WOT pull a day up to highway speed to hoping things will continue to seat and consumption subside. Not going to worry until after 3000mi.
#120
Here’s an update, used about 1.25 quarts the first 3000 miles. Got an oil change at 4700 miles. Now have 6200 miles and no sign of oil usage. Been driving it a lot on the highway at speeds of 75 or so mph. Like what I am seeing. This is what my last 5.0 did, just needed to break it in. So far I am happy.
