1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
5.4 2v Coil Pack
Old 03-03-2019, 09:17 PM
99f350sd's Avatar
99f350sd
99f350sd is online now
With that many miles I would change them all.. The coils. The connectors in the coils get corroded. The bolt area cracks etc. Just did mine. like $220 from amazon only use motorcraft coils imo.
DG508
Old 03-03-2019, 09:21 PM
99f350sd's Avatar
99f350sd
Originally Posted by SuperDutyScaler
My 2004 f350 with the 2valve 5.4 just hit 170k last night. I have ALL ORIGINAL COP's still...I do change the spark plugs and the boots/springs ever 30k since new. Motorcraft spark plugs with silver nerverseize and ACDelco boots (acdelco were original equipment)
Correct plugs are good for 100k I would do 80k. get some new cops and leave the plugs for a while.
Old 03-03-2019, 11:07 PM
R&T Babich's Avatar
R&T Babich
R&T Babich is offline
Are you sure the OEM boots are AC Delco?
I have read several people saying that Denso was the supplier for the OEM COPs.
Old 03-04-2019, 07:36 AM
idealtrucks's Avatar
idealtrucks
idealtrucks is offline
I have the torque app and one the bluetooth modules, but there are no codes being thrown. No check engine light. From what I read I will need one of the OBD tools with Mode 6 capabilities.
Old 03-04-2019, 07:49 AM
redford's Avatar
redford
redford is offline
Received 1,562 Likes on 910 Posts
You will need to look at PENDING CODES to see the misfire. You practically have to have a dead cylinder before an error code is set, so pending codes are your best friend.
Old 03-04-2019, 07:56 AM
idealtrucks
I will try that with the bluetooth adapter I have. Are they all equal as far as the data they return? I paid 99 cents for mine off Ebay
Old 03-04-2019, 09:09 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Put the Torque app on "test results" and drive it. The Mode 6 test 53 misfire results will show up eventually, looks like this:
misfire counts in Torque app on "test results", the last digit is the cylinder #
Old 03-04-2019, 09:12 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
The original COP assembly is a Denso product not a AC Delco product.
Old 03-04-2019, 11:14 AM
kcducttaper's Avatar
kcducttaper
kcducttaper is offline
I'm having the same issue with my '99 5.4 2v with 65k on it. Pulling a 10k 5th wheel, it definitely gets annoying. I don't daily drive mine, but I'll try to remember to hook up my Blue Driver OBD II scanner to see what it says next time I drive it. It has mode 6 data, can scan all the systems (not just the CEL codes), and it a pretty good deal for $100, IMO.
Old 03-04-2019, 01:01 PM
idealtrucks
I went out at lunch and tried an app on my laptop that pulled $53 codes, but the CID listed with them weren't cylinder numbers. I'm assuming I should see 1-A or 0-9.
I couldn't try the torque app on my phone since bluetooth isn't working, so I'll get a tablet when i get home and give the Torque app a try.
Old 03-04-2019, 03:26 PM
Fefanatic's Avatar
Fefanatic
Fefanatic is offline
You should get a P03xx code. xx would equal the cylinder number. P0303 would be cylinder 3. FWIW, if your check engine light flashes that is an indication of a misfire and that code should be set.
Old 03-04-2019, 08:07 PM
idealtrucks
I downloaded the Forscan app for my computer, and it's showing misfire for cylinder 8. So I'll do some troubleshooting with coil/boot on that cylinder this weekend.
When I opened up the forscan app, I did have 3 trouble codes showing, but the check engine light is not on. P1000, P0316, and P0325. Should I be concerned about eh P0325 code or is also related to the misfire issue? Why would it show on this app, but not have a check engine light ? It also didn't show on the torque app (lite).
  #28
Old 03-04-2019, 10:57 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
  #29
Old 03-05-2019, 05:36 AM
99f350sd's Avatar
99f350sd
Just a note. Some early ford's won't throw a missed cyl code at all. The computer just can't do it for some reason. Disconnect it yes or short it yes but miss fire good luck.
  #30
Old 03-18-2019, 05:15 PM
Rogue*'s Avatar
Rogue*
Rogue* is offline
The coils are probably just fine.
If the boots are OEM with 130k I would change all the boots, Denso 671-0001, Rock Auto, $32 for 10 boots.
Good Info.....thanks
Quick Reply: 5.4 2v Coil Pack
