5.4 2v Coil Pack
Correct plugs are good for 100k I would do 80k. get some new cops and leave the plugs for a while.
I have read several people saying that Denso was the supplier for the OEM COPs.
on
misfire counts in Torque app on "test results", the last digit is the cylinder #
I'm having the same issue with my '99 5.4 2v with 65k on it. Pulling a 10k 5th wheel, it definitely gets annoying. I don't daily drive mine, but I'll try to remember to hook up my Blue Driver OBD II scanner to see what it says next time I drive it. It has mode 6 data, can scan all the systems (not just the CEL codes), and it a pretty good deal for $100, IMO.
I went out at lunch and tried an app on my laptop that pulled $53 codes, but the CID listed with them weren't cylinder numbers. I'm assuming I should see 1-A or 0-9.
I couldn't try the torque app on my phone since bluetooth isn't working, so I'll get a tablet when i get home and give the Torque app a try.
I downloaded the Forscan app for my computer, and it's showing misfire for cylinder 8. So I'll do some troubleshooting with coil/boot on that cylinder this weekend.
When I opened up the forscan app, I did have 3 trouble codes showing, but the check engine light is not on. P1000, P0316, and P0325. Should I be concerned about eh P0325 code or is also related to the misfire issue? Why would it show on this app, but not have a check engine light ? It also didn't show on the torque app (lite).
#29
#30
