Mustang 2 clip
#46
Update. Removed the springs yesterday....and they have been cut. The length of the springs has been reduced to 11". Almost 1.75" off of the original manufactured length. (Pretty much a full coil). Also before I dismantled I did an experiment. I jacked the truck up on the chassis rail allowing the suspension to drop down. I then chalked the bottom half of each shock absorber. Next I took the truck out down a bumpy gravel road nearby. When I jacked up the truck again the chalk had been transferred to the rubber washer/seal on the top half of the shox. As suspected the shox are bottoming out. Luckily I have obtained from a rodder over here a brand new set of 400lb springs. I hope to get them fitted tomorrow and give the truck a good test drive. I will keep you all posted when completed.
Suffolkman
New pair stock springs & my chopped coil
Suffolkman
#47
Received 4,114 Likes
on
#48
Suffolkman
#49
on
#50
#51
I wouldn't expect the full 1.75" in ride height since there will be some compression loss. But you should see at least an inch of height adjustment, and a greatly improved driving experience with better springs and no bottoming out. As I mentioned before, the cut springs will be harder to compress, effectively increasing the spring rate. So even with the same initial rating, you should have a smoother ride with the full length springs.
#53
on
I'm pretty sure he has it all figured out now with the proper length spring
#54
on
Yes John maybe I could have explained it better I wasn't suggesting he move the spring mount . . If you move the middle of the control arm 1 inch the outer end will move more than that relevent to where the spring is situated on the control arm . I am not good with links but if you research " arc length " it will explain it much better than me .LOL
#55
on
#56
on
Yes it's pivot point is fixed but if you move the center of the arc 1 inch " longer spring " the outer end of the arc "tire " will move more than 1 inch . If your spring is mounted in a position similar to P or 1 on the left side of the diagram then the outer end " tire " at k1 will move 1.5 .
#57
The part you're all missing is the arc and pivot points are not static. The center of the true axis is not where the control arm connects to the chassis, it's farther inboard closer to the center of the vehicle. The entire vehicle moves as you change the spring length. The calculation is a bit more difficult than displayed. I know how it works, but the math to describe it is way above my pay grade. Higher math was not my strong suit.
#58
on
#60
However, the two springs will collapse differently when the weight is applied. The length difference will be less than the 1.75" when loaded. How much less will depend on the weight applied. There's a lot of variables to consider when calculating ride height and comparing different length and spring rate of the springs.
