Bill/Numbers, anyone,,
Old 03-02-2019, 01:05 PM
lafermedavid
lafermedavid is online now
lafermedavid is gaining momentum as a positive member of FTE.lafermedavid is gaining momentum as a positive member of FTE.
hear is a 302 on 360 stands I drove for years in front of a np435 Iknow its not related to your situation ,but might narrow it down
Old 03-02-2019, 03:41 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by Pickupmanx2 View Post
Looking at the pics, the supports on the 4wd V8/I6 are the same #,,, the insulators are what's different, that is what cornfuses me I know on a 2wd I just unbolt, and move the supports forward.
You cannot assume the parts are the same, because only basic part numbers are used in pics and Ford has used the same basic part numbers for decades.
For example, every front rubber insulator is basic number 6038, makes no difference if it's a 1961 Lincoln or a 2019 Lincoln.
The text section of the catalog is required to add the apropos prefix and suffix to the basic number, to get the complete part number.
Old 03-02-2019, 03:46 PM
lafermedavid
Thanks Bill trial and error
Old 03-03-2019, 03:44 PM
Pickupmanx2's Avatar
Pickupmanx2
Pickupmanx2 is offline
Pickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to beholdPickupmanx2 is a splendid one to behold
Ahhhh,,, said the knucklehead to the genius Thanks Bill!
Old 03-03-2019, 04:31 PM
lafermedavid
Sleepy445FE
Sleepy445FE
just looking at old threads and found this ,you might want to give a 360 4x4 towers a shot
They make similiar power. The I6 at a lower rpm. The 300 will get better mpgs than the 351m,but the V8 is going to sound better. It's all on what you prefer and whats most important to you. Sound or mpgs? There are upgrades for both, 400 crank swap in the 351 is well known. I'll probably offend some of the 335series guys but the 300 I6 will almost definitely outlast the 351m.
The mounts for the FE engine(360/390) from 73?-76 are the same as the 300.
Old 03-07-2019, 10:48 AM
Pickupmanx2
Having 0 luck finding mounts,,,, not many yards here in central CA to pick from,, anyone have any laying around
Old 03-07-2019, 11:48 AM
fordguy2100's Avatar
fordguy2100
fordguy2100 is online now
fordguy2100 has a good reputation on FTE.fordguy2100 has a good reputation on FTE.
Sorry lot of cross talk above, don't know which parts you need but I have these two sets. Don't know anything about them but let me know if one of those is what you need
Old 03-07-2019, 01:20 PM
NumberDummy
Originally Posted by fordguy2100 View Post
Sorry lot of cross talk above, don't know which parts you need but I have these two sets. Don't know anything about them but let me know if one of those is what you need.
Look at the lower pic in post #7, these are 2WD engine supports (aka towers/stands/perches), will not work on 4WD (shown in upper pic in post #7).
OP has a 1977 F250 4WD
Old 03-07-2019, 02:15 PM
fordguy2100
Like I said, didn't know what he wanted. Lots of talk of 2wd and 4wd...
Also I have two sets posted....so I assume (after checking your post) that my second set is for 2wd trucks and is the set you are referring to.
However To me my first pic looks like the towers in your first pic. so are those not 4wd perches?
Old 03-07-2019, 02:32 PM
NumberDummy
Both types are 2WD
2WD's have an engine cross member, 4WD's do not.
2WD supports bolt to the frame rail on one end, to the cross member on the other end (see pic below).
4WD supports only bolt to the frame rails.
Old 03-07-2019, 02:39 PM
fordguy2100
Both types are 2WD
Ah I see the angle difference now. So yeah that first set would still need a cross member for the bottom bolts. Do you know which engines that first set fits? Makes it easier for me to sell if I know what they go to lol.
The second set looks like the pic you posted so i assume it's for the engines listed. Or are they for the same motors just different years?
Sorry for the Thread hi jack
Sorry I can't help OP
Old 03-07-2019, 02:57 PM
NumberDummy
Upper/Lower pics from post #7 // 2WD (lower) pic also in post #25 // See the captions for engine sizes.
  #28
Old 03-07-2019, 03:47 PM
fordguy2100
Edit* nvm I see there is a small pic within pic 2 that hast first set pictured
  #29
Old 03-07-2019, 04:50 PM
Pickupmanx2
Thank you! And thank you Bill! The search continues
  #30
Old 03-15-2019, 11:09 AM
lafermedavid
Bill Kindleyto 73-79 ford truck ISO, for sale or trade and related parts
14 hrs This guy has your stands give him a write,,,,,he is not too far from me if he wont ship let me knowdave
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
