Wanted disk brake spindles for 66 f100
73-79 half ton 2WD will fit using the king pin set to match the spindles. Must salvage yards sell what they call the "front knuckle" spindle, caliper, rotor - basically kingpin out. Also request the brackets bolted to the frame for each side where the brake line and brake hose come together. I also would recommend asking for the master cylinder/booster assembly and the proportioning valve. Price will vary by region and whether they pull or you pull - range $150-350. Old components are cores for rebuilt units and allow you to get everything lined up.
Yes, I have the ability to read and understand what is written. The spindles are not reproduced unless they are a component in a complete conversion kit (very expensive). So your only choice is to source from a 79 or earlier truck as a used part; salvage yards almost always want to sell you everything from the king pin out. Just trying to help, feel free to ignore.
There are no specific disc brake spindles for 1966 F100's because disc brakes were not available for F100 2WD's until 1973.
1973/74 spindles are different than 1975/79 spindles. 1980 and later spindles will not work.
You should get all the parts from one truck so when you need replacements parts, you'll know what the applications are.
D3TZ-3105-A .. Right Spindle / Stamped with ID number: D3TA-3107-CD or DD / Obsolete
D3TZ-3106-A .. Left Spindle / Stamped with ID number: D3TA-3108-CD or DD / Obsolete
1973/74 F100 2WD
D5TZ-3105-A .. Right Spindle / Stamped with ID number: D5TA-3107-FB / Obsolete
D5TZ-3106-A .. Left Spindle / Stamped with ID number: D5TA-3108-FB / Obsolete
1975/79 F100/150 2WD
1973/74 F100 2WD
I have original spindle for ‘66 Ford F100. ONLY ONE SPINDLE
I have one original spindle from a 1966 Ford F 100 if you’re interested. 2014067406
jbruce4390
13
08-20-2012 08:05 AM
T2Load
02-16-2003 05:07 PM
