time for brakes or not?
Old 02-23-2019, 10:35 AM
senix's Avatar
senix
senix is offline
Received 1,415 Likes on 1,010 Posts
Opinions wanted.
Do you think they need replaced yet or wait until the end of the season? I am repacking wheel bearings so thought I'd see what everyone thinks. This is on the door side rear axle. Door side front looks comparable so even wear on this side of the trailer.
Have not looked at the other side but I'd expect about the same.
No cracking or signs of failure on these two.
As far as miles are concerned I added it up one time and I recall total miles being north of 25K.
Old 02-23-2019, 10:57 AM
kgburns's Avatar
kgburns
kgburns is offline
I'd keep on running those then check again before you put her up for the winter.
Old 02-23-2019, 11:24 AM
senix's Avatar
senix
senix is offline
Thanks. I figured the same. I plan on only about 8K this summer so I think it will be fine for that.
Old 02-23-2019, 06:14 PM
69cj's Avatar
69cj
69cj is offline
When I replaced mine, I just bought the whole backing plate pre-loaded with the pads and new magnets. Drums were well within specs so just had them turned. When the four dots on the magnet start to disappear it’s getting to be time. Your good for the remainder opinion.
Old 02-24-2019, 04:36 AM
avf100's Avatar
avf100
avf100 is online now
I would change them now while you have it apart. No sense in doing the work twice, unless you don't have the time to wait for the parts.
Old 02-24-2019, 08:16 AM
rvpuller's Avatar
rvpuller
rvpuller is offline
It's hard to say by just looking at one because they don't wear evenly from one wheel to the next because of voltage drop and each wheel has individual parts that can act differently. I would also check the tab the magnet sets on to make sure it's solid and then look at the magnet to make sure you can't see the coil embedded in the epoxy, if you can replace them. Next look at the surface the coil makes contact with and see if it's smooth. If you decide to replace them I would get complete backing plate assemblies so you start with all new parts.
Demny
Old 02-24-2019, 10:54 AM
senix's Avatar
senix
senix is offline
Attached is the front one, door side. I have not taken the others off yet. Plan to do those next weekend.
To me, Denny, everything you mentioned to check for seems good. I do agree getting the complete assembly will be the way to go.
Old 02-24-2019, 11:37 AM
rvpuller's Avatar
rvpuller
rvpuller is offline
The shoes normally don't have thick lining like cars do so they look safe for now but don't be surprised if the left side has a little more wear because of voltage drop if your wires are feed from that side. I've always contributed the drop from the small wires running through the axles. If the other side looks close to this side I think you will be safe for smother another year. I would strongly consider converting to disk brakes in the future if you plan on keeping the trailer, I'm glad I did but we plan on keeping the trailer until it's no longer serviceable.
Denny
Old 02-24-2019, 11:42 AM
senix's Avatar
senix
senix is offline
A disc conversation is a high consideration. I might look into that for a winter project next year.
Old 02-24-2019, 12:07 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
It wasn't really all that hard to do and now that I have them I wouldn't be without them.
Denny
Old 02-24-2019, 06:07 PM
'65Ford's Avatar
'65Ford
'65Ford is offline
Since the drums are off, might look at the drum face where the magnet rides. A groove (0.020" or so) can decrease your braking power. I want so say you can have up to 0.030" taken off the face but verify that amount...I could be mistaken on the amount.
Old 02-24-2019, 06:13 PM
senix's Avatar
senix
senix is offline
drums did not have noticeable grooving.
Old 02-25-2019, 08:08 AM
wrvond's Avatar
wrvond
wrvond is offline
I seem to recall the magnets on mine being on top. I wonder if it makes a difference.
Old 02-25-2019, 09:02 AM
rvpuller's Avatar
rvpuller
rvpuller is offline
I've had a few apart and have never seen any on top
Denny
Old 02-25-2019, 10:24 AM
wrvond's Avatar
wrvond
wrvond is offline
Denny
I must be mistaken. Can't find any photos from the last time I had them apart, but went to eTrailer and all of them show the magnet at the bottom.
Just gettin' old, I guess.
Quick Reply: time for brakes or not?
