New transmission or rebuild advice
Old 02-21-2019, 08:12 PM
alaskapilot95's Avatar
alaskapilot95
alaskapilot95 is offline
Hey guys today wasn’t a good day. Started out with my camper and trailer and got an hour from home when my trans started overheating. Got to 200 so pulled over went to 223 then came back down after a while of waiting. Got on the highway at that point stayed around 170-185. Got off the highway with less than 15 miles to go and it started to get warmer. Got on this windy road that had no turn offs and had no where to pull off when it got close to 200 again. Finally got to a straight spot where we wouldn’t get hit but it was at 215 and right after I stopped to let it cool down (still running in N) it climbed all the way to 253. Fluid everywhere with barely any left in the trans. Was coming out right next to the tc by the looks of it. So going to a shop tomorrow who might be able to help. Trucks still drivable but don’t trust it going far but wondering if I should get a rebuilt one have them rebuild it or wondering if maybe just blocked cooler and TC. All my mods are in my signature. Thanks in advance guys. This really threw me off today and really don’t have the money to spend on a new transmission
Old 02-21-2019, 08:15 PM
alaskapilot95
Sorry don’t know why Signatures not posting. TS6 position, 6637, van turbo, stock tires
Old 02-21-2019, 08:53 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
Sounds like the front pump seal, often you can just replace the seal and all is well. It happens a lot when people back their trailer up.
Old 02-21-2019, 09:10 PM
alaskapilot95
I should add that the cooler was cold when it was overheating at 250. So I don’t think it was cooling at all either
Old 02-22-2019, 07:33 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
Mark Kovalsky will be your best source of information on this. Signatures don't show when posting from a mobile device.
Old 02-22-2019, 10:24 AM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,180 Likes on 811 Posts
Probably the by-pass valve is stuck open.
Old 02-22-2019, 10:27 AM
alaskapilot95
Yeah it does sound like the bypass is clogged or broken causing it to overheat. Thing is though it was up to 223 and then up to 253 at different times. That would lead me to think that it is probably cooked on the inside now. With my last trans fluid change I did it almost looked like I was changing oil because it was so black. I’m leaning towards a new transmission as we will be headed back to Alaska with it after traveling around the lower 48 and don’t want to get stranded in the middle of no where. Been suggested streetsmart transmission and reading a lot of good reviews on them. $1880 shipped seems to be a good deal. Any input on them?
Old 02-22-2019, 10:28 AM
z31freakify
250° wont damage it, as long as you dont go driving with that temp for a while.
Old 02-22-2019, 10:30 AM
alaskapilot95
I understand that but with the black fluid and the front seal that now leaks even at normal temperatures it just doesn’t seem like a very good use of money to replace the seal for say $1000 and have the trans die in a couple thousand miles.
Old 02-22-2019, 10:44 AM
z31freakify
Ouch! black fluid isn't good, hopefully Mark K. Can jump on this discussion.
Old 02-22-2019, 11:10 AM
roostercrows's Avatar
roostercrows
roostercrows is offline
How many miles on your truck?
Pretty much the same thing happened to me this past summer, I did a new tranny for the piece of mind.
Any other known issues with the truck?
Old 02-22-2019, 11:42 AM
alaskapilot95
I don’t have any other problems. I’ve pretty much fixed most the other stuff. I haven’t really had any Major problems. Engine has 125,000 miles on it now. Swapped that in last spring as the other one had lots of blow by. Price quoted from streetsmart they are $1880 not installed but don’t have warranty in Alaska where I live. So looking at other places down here in PA currently waiting for the dealer to give me a call back with their probably crazy price.
alaskapilot95
Sorry engine has 125,000 truck has 117,000
Old 02-22-2019, 12:22 PM
RigCity's Avatar
RigCity
RigCity is offline
You can pay the labor to take out the old unit or possibly pay a mechanic hourly to rebuild plenty of possible surprises that way. I would only advise a rebuild if you are going to do some serious upgrades. When I did mine the rebuild vs replacement. The replacement will also minimize the trucks down time
Old 02-22-2019, 12:40 PM
pirate4x4_camo
Front pump seal is $8 and a easy DIY project. You can rent a trans jack and do it in your driveway.
https://racerxusa.com/product_info.php?products_id=86
a 3 foot long 1/2” extension and a 19mm impact wobble socket are the only speciality tools needed.
Quick Reply: New transmission or rebuild advice
