Rocker upgrade for 300 I6 rebuild
Here is the Cam List for catalog cams.
https://fordsix.com/viewtopic.php?p=613117#p613117
If you are looking for a nice idle at 650 rpm and a wide power band I would recommend the Crower 266HDP (19213) .456”/.461” 210/213 266/274 112deg
The 112 degrees LSA will provide a smooth idle and the 210/213 .050" specs will give you a good midrange power with a moderately ported head.
This cam will allow up to a 9:1 compression ratio with regular pump gas.
The Comp cams are detonation prone and the Crane cams with the long exhaust durations are antiquated carry overs from the early SBC profiles.
Stock 300 head pre 1985 valves are 4.810" long.
What valves did you use?
The Offy C is a good choice.
The Dual plane doesn't seem to offer any better low end response but the split runner does seem to be a restriction on airflow for the upper part of the power band.
What I don't like about the DP is it forces you to mount the Carb sideways exposing the fuel bowls to the rising exhaust manifold heat and effecting float bowl levels during turns.
The EFI exhaust is definitely an improvement over the log manifold.
I don't know of anyone that has been happy with the Edelbrock Carb on the 300 six. Tuning for gas mileage is one of the complaints.
I would strongly suggest the Summit M2008 500 cfm carb. https://www.summitracing.com/parts/s...00vs/overview/
It has Annular Boosters which works very well with cold intake manifolds.
The only reason why I used the Clifford intake was because I got it cheap off of Ebay.
I prefer the new Offy "C"
The only problem I see with the Summit carb is that it appears to be more susceptible to heat soak after the engine is off.
There was a heat soak problem on the DP manifold because of the sideways orientation.
There is another that may be tested in the early Van closed engine box.
The Carb also comes with a thick insulting spacer to be used between the carb and intake manifold.
You could also heat wrap the EFI exhaust manifolds which would lower the heat in the engine compartment.
About connecting rods and pistons:
The stock rods are forged steel and we just resize the rods with ARP bolts. Stock rods work fine up to 5500 rpm on a naturally aspirated build.
There aren't any "off the shelf" forged pistons for the 1969 and later 300.
Autotec is the least expensive custom forged piston at $562.50 for a set of six dish pistons.
The other choice is to bush your connecting rods ends from .975" down to .912" and use Ford 351 V8 forged pistons.
Depending on how much your machinist wants to charge to bush the rods plus the price of the 351 forged pistons it may be cheaper the get the AutoTec pistons.
#29
#30
Leote
The Harland Sharp rockers lubricate through the pushrods.
The 1985 to 1996 4.9 engines do not use stud mount rockers like the Harland Sharp S4002.
These later model heads use pedestal mount rockers.
If you want to use Harland Sharp rockers the head will need to be drilled and tapped for screw-in rocker studs.
You will also need pushrod guides and hardened shaft pushrods.
What camshaft are you using?
