New TSB to correct warped Dash
I imagine if you put the request in during warranty you'll hopefully be okay. It'd be pretty terrible if due to them dragging their feet you all of sudden don't get your TSB anymore.
I'm hoping that will be the case, but I'd hate to have to fight it. I've been lucky to not have a good relationship, or at least not close, with my local service departments.
So they have been having this problem for 4 years and have not fixed it with a better dash ? Just like the the freezing door latches they are STILL putting in trucks. When you are number 1 and cranking them out like sardine cans there is no incentive to improve anything in the overpriced junk you are selling .....
I guess I will try the heat gun if this doesn't. I thought about making a heat shield with foil and going very gingerly with the heat. I have an infrared thermometer. How hot should I get it if I try?
That dash is bound to be able to withstand 140 or so.
boy, I can't spell tonight
Last edited by bedwards; 03-09-2019 at 09:24 PM. Reason: boy, I can't spell tonight
#30
Yep, that's the culprit. I was scheduled to get mine done yesterday as well as the transmission reflash tsb, but when they called to say the truck was ready, only the transmission update was done. Strangely, they set up the appointment to do the dash by calling me to say they got it in after I requested the replacement at my last oil change. However, I was told in the phone call that it was backordered. I wondered to myself if they would be willing to put in a lariat trim dash panel if I paid the difference since those are likely not backordered, and would eliminate the potential for a repeat issue.
