2012 6.2 not heating up
A properly functioning thermostat and cooling system is supposed to adapt to a fairly wide range of environmental temperatures, as correct engine temperature is important for emissions and fuel economy. I agree that the gauge isn’t linear, which to me is all the more reason for concern if indicated temperature is not in the “normal” range.
HTH,
Jim / crewzer
On mine the temps seem to stay a tad low as well. 150 to 160 for a while before it finally sits around 180. Seen this before on my previous truck and it went away after I changed with a new oem thermostat.
Anyone here changed this thermostat ? I took a look and it seems the plastic intake is right on top of it. Service manual says it doesn't need to come off, only the flexible hose from the air filter to the intake. Anyone done the thermostat change ?
bigb56
12-30-2017 01:25 PM
DIYMechanic
13
12-16-2010 08:10 AM
