T19 hard downshift 3rd to 2nd only when cold
Not all the way in not really a little in just a hint of going into 1st.
The thought is the synchro will speed up the gears a little to help it get into 2nd.
You could also try dubble clutching bringing the RPM up a little. Like you would if floating gears.
Dave - - - -
Dave - - - -
So pull it out of 3rd, pull it toward your leg and then push forward for a split second and then pull it back to 2nd gear and then let out the clutch.
I had some cold weather issues with 80w90 GL4 oil. A bit of whining and stubbornness to change gears in temps < 10F. I later switched to SAE50 and the cold weather performance improved noticeably. It's still a tad stiff for the first few miles when real cold out, but I imagine that's a fairly normal characteristic.
sawyersvintage
08-12-2011 07:19 PM
