removing dash for TBC install
Has anyone installed a TBC? I have a few questions about removing trim to install it. I don't want to break any of it I'v seen the video on here about doing it but it's not very detailed. I'm a little ski-dish about doing it attempted last night but it did not come apart like I thought.
Also, if this is the first time any panels in your truck have been removed, they will be kind of hard to remove and you might think you`re going to break something but if you just take your time, you should be fine.
Yah. The only screws that need to be removed are the ones around the speaker on top of the dash. You can just do the back two, and leave the front half connected, or you can remove the speaker grill (it is just held with clips), and remove all 4.
And you don't really need to R&R the "dash". Just the bezel around the infotainment system, and the left shroud around the vent.
All I can say is make sure you use the correct part number TBC there is one for 2018+ and the earlier part number for 2015-2017 trucks will not work. Another issue is the possibility your fuse box is missing the supporting circuit in the fuse box.
Pastortom1
02-13-2013 09:39 AM
TheMachfather
01-18-2004 11:49 PM
