2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
SunRoof Shade noise
Old 02-18-2019, 01:04 PM
BigTexDiesal
BigTexDiesal is offline
BigTexDiesal is starting off with a positive reputation.
SunRoof Shade noise
Hello,
I get a horrible squeaking sound when opening and closing my sunroof shade. Is there an easy solution besides not using? My rear slide window make grinding noise when opening and closing as an added bonus. Any suggestions greatly appreciated!!!
Old 02-18-2019, 08:00 PM
dkriplean
dkriplean is offline
dkriplean is starting off with a positive reputation.
Following. I have the same issue
Old 02-18-2019, 09:01 PM
f350ktm's Avatar
f350ktm
f350ktm is offline
f350ktm is gaining momentum as a positive member of FTE.
The sunroof itself does have rails that require lubrication. I check those guide rails regularly to be sure they are clean. Have not needed to lubricate them yet.
I have not checked the shade, perhaps it needs lube also?
Old 02-19-2019, 04:20 PM
BigTexDiesal
I have to check surprised nobody else has the noise or suggestion. Sounds horrible.
Old 02-19-2019, 05:20 PM
Retiredout
Retiredout is offline
Retiredout is starting off with a positive reputation.
Originally Posted by BigTexDiesal View Post
Hello,
What year, make and model? How many miles do you have on it?
Old 02-19-2019, 05:30 PM
BigTexDiesal
2017 f250 with 5 k miles built in 11/2017
Old 02-19-2019, 08:30 PM
copper1977's Avatar
copper1977
copper1977 is offline
copper1977 is starting off with a positive reputation.
My 2017 (10/17 build date) with 5k miles had the exact sun shade noise you are describing. The dealership replaced it in a couple of days. Let me correct myself...the dealership sent it to a sunroof shop to replace it.
Old 02-19-2019, 09:12 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.mhoefer has a great reputation on FTE.
I have a October 2916 build 2017 F350 Crew LB, never ever heard noise from the shade or the rear slider. It’s a Lariat Ultimate. I would definitely take to the dealer and have it noted from warranty perspective. Not normal, can it be replicated, does it always do it, take video of it doing it it.
Old 02-19-2019, 09:15 PM
BigTexDiesal
Mine is also a lariat ultimate. It can be heard every time. I will take it in. My rear slider sounds like sand in a gearbox. It was quiet for the first 2 months of ownership, lol.
Old 02-19-2019, 09:34 PM
Carnac22
Carnac22 is offline
Carnac22 is starting off with a positive reputation.
I have a 2017 F-250 Platinum with 22,000 miles. I open the sun shade almost everyday in the winter for the drive to work and close it while I'm at work. So, it gets cycled pretty regularly.
No squeak at all.
I have never lubed the rails, but I may take a look and see if there is access to wipe some silicone lube on them.
Jim
Old 05-13-2019, 08:26 AM
Billmnfl
Billmnfl is offline
Billmnfl is starting off with a positive reputation.
Sunroof shade inop
Does anybody have any info on how to gain access to the Sun Shade Motor and Shade Assembly?
I just bought my 2016 Transit connect and the dealer informed me that it was inop and had a $3000 estimate to change the motor. Can't be that big a deal....or maybe I am wrong. Maybe they hanged a motor from a string and built the Van around it.
Any info will be helpful and appreciated.
Thanks.
Billmnfl
Old 05-13-2019, 11:40 AM
2017-350's Avatar
2017-350
2017-350 is online now
2017-350 is starting off with a positive reputation.
My shade was making the same noise as described and even some popping....the dealer replaced it without hesitation
Old 05-13-2019, 01:40 PM
Billmnfl
Billmnfl is offline
I just bought the Van used and it is out of warranty. They told me about it but didn't want to fix it.
I, however, will find a way.
Old 05-14-2019, 11:17 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
Billmnfl see the other thread on $200 fix of sunroof rails. It’s in this forum 2017+ Superduties. Aftermarket, bit of a job but reports great results for much less than $3000 repair.
Old 05-15-2019, 11:08 AM
Billmnfl
Billmnfl is offline
mhoefer, thanks for the info. I will check it out.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
