Brake Booster Replacement - 4 Wheel Drums
I can get the system to bleed when the truck is off with. It has solid pedal pressure. As soon as the truck starts I lose all pedal pressure and it goes to the floor. No brakes whatsoever. Also, no leaks that I can spot anywhere. I've asked around to a few folks and it sounds like my issue could be the brake booster. I've found a couple options around the web. Do I need an adjustable pushrod? I'd also be open to any options that I could pick up used.
I'm pretty sure what MPH is saying, If your hydrolic system is right its not the booster. The booster aids in the ease of pushing the pedal. Sounds like a bad M/C or bad distribution block.
This is a new M/C from Rock Auto that I bought a couple years ago. It was the cheapest one on the list... I can pick up another one and give it a shot. Any thoughts on how I can check the distribution block? Is there another name for that? i don't see it on Rock Auto.
And remember, just because it is new doesn’t mean it’s good. Go with a NEW M/C in lieu of a rebuilt on. Your life depends on it.
Dave145
38
12-21-2017 12:29 PM
hawncase
10-08-2012 06:29 PM
nalarangka
06-30-2004 11:16 AM
