40/20/40 seats from crew cab to super cab??? what am i missing
I have a 96 supercab with this bench
would like to put these seats in it from a crew cab, but still have access to the back for passangers
with this sliding floorpan from a crew cab is this all I need to gain access to the back of my supercab? (doner is a 4 door 96 crew cab) I have spent 2hrs. on this forum reading seat swap article after article no definitive answer... thanks in advance!!!
Seat pans from a crew cab will only bolt in another crew cab or regular cab regardless of front or rear position. They will not work in a super cab without modification. Seat pans and the floor boards in a super cab are completely different. Do another search it has been covered many times before.
would like to put these seats in it from a crew cab, but still have access to the back for passengers
The 40/20/40 from a crew cab/regular cab a DIRECT bolt in for your split back bench out of your supercab.
NOW, to the problem. The crewcab/regular cab seats do NOT slide far enough forward to access the rear of the supercab.
The supercab brackets have 2 sliders. One for seat adjustment, and one for fully sliding forward to access the rear
Its a shame you are not closer, I could trade you some supercab brackets
I sorta wish they’d made a 3 piece back on a bench instead of the split, you’d gain the underneath room back and all you’d lose from the normal 40/20/40 is the independent slide. But, that part is nice - the tall one in the back can ride behind the passenger and my knees aren’t in the steering wheel
Dont quote me but I am almost positive the holes are there and so are the bosses, but they are not threaded for the 4 inner holes
12valveEx
06-15-2015 04:25 PM
mando jake
26
02-12-2008 03:27 PM
