53 paint code R
My 54 with an NOS floor mat I put in in 1999
Looking around last night, saw a headliner kit. Does that include ceiling, back of cab around window, and tops of sides around door? To finish the interior, the other things I would need would be the kick panels and a floor mat?
I am hoping the 53 F250 is the basically the same as my 53 F500. I have posted this question before. People say they are basically the same. I have had real good luck with the parts I bought fitting so far.
Thanks!
Yes, the cabs interior is the same for all size trucks.
Yes, the headliner includes all that you listed above. To see a headliner not installed go to BJ Mayberrys thread called family 56. He just bought one.
First round of Bondo.
Looks like I will be using paint from NAPA called Crossfire from Martin Senour . They are the only ones around in the area that mix automotive paint
There is a local PPG dealer but dont mix automotive here. I think they can get Shop Line brand
I have not checked with the local garage paint/body shops yet.
Not sure what to do with the gas tank hole behind the passenger side door. I moved gas tank back to under the driver side seat where it should be. Should I weld some sheet metal on the back side and fill with Bondo or put a rubber hose grommet in and filler hose with locking gas cap so no one can put gas in accidentally. Filling in he would be the right way to go.
I have a quart of the Crossfire Martin Seymour Meadow Green acrylic enamel paint. I need to prime the truck first. Do I have to stick with the same brand of primer or can I put a different brand on?
Which of the following ways would be easier? Paint the doors while on the truck or hang them up and paint? They are currently off the truck and all glass, trim, and handles removed.
#30
MikeRich-webber
02-14-2003 09:26 AM
