Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
Currently in the garage and need help with OEM Led headlights
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 02-17-2019, 09:44 PM
Mack3006
Mack3006 is online now
Mack3006 is starting off with a positive reputation.
The retrofit source.com has the kit headlights for $2000. Harness kit is $300
LEDEVERYTHING coupon code is 10% (-$230 off)
so for $2070 for the package itís not bad.
Fogs are an extra $175
how much is the stuff for Ford Scan ?
Amd side note. I purchased the 6 bulb kit from headlight revolution. Supernova V3. With in 11 months, one fog and one headlight bulb failed. I called and got replacements but customer service wasnít the best. They sent me Version 4ís. Suppose to be better and brighter. Not At all. Also the Fogs has the wrong size bezel and they had to send more replacements that were ďfiled downĒ. Also there not extending my 2 year warranty. I went with the so called Highend bulb, figuring I would put them in once and not have to worry about them for years.
I donít have to much faith in the new bulbs. After spending about $500 and a few hours installing the both sets. (12 bulbs) . I wish I would have done an OEM LED conversation
I have having to do **** over.
Old 02-18-2019, 06:24 PM
nico963's Avatar
nico963
nico963 is offline
nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.nico963 has a great reputation on FTE.
Originally Posted by mhoefer View Post
Nico, I will have to wait to get the computer from work and hook it up.
Hey whenever,I just appreciate the help!
Old 02-18-2019, 06:26 PM
nico963's Avatar
nico963
nico963 is offline
I thought it was a good deal.Thats exactly what I paid...$2070 shipped.Its all new stuff and comes with a two year warranty.
Old 02-18-2019, 06:36 PM
nico963's Avatar
nico963
nico963 is offline
Originally Posted by JustMe1616 View Post
Thanks, I hope it all works out for ya. If you don't mind, post some pictures when your done. Would love to see it. Once again, thanks.
This is all I have right now,The truck is still not all the way put back together.
I also did Rigid industryís D2 Pros for my fogs with KD Fabworks mount.
Old 02-18-2019, 08:12 PM
Maiden666's Avatar
Maiden666
Maiden666 is offline
Airbus driver
Maiden666 is starting off with a positive reputation.
Much more light with the Rigids?
Old 02-18-2019, 09:53 PM
nico963's Avatar
nico963
nico963 is offline
Yes,With my four Iíll have alittle over 19k Raw Lumens.
Old 02-21-2019, 04:42 PM
nico963's Avatar
nico963
nico963 is offline
Alittle update,I called Retrofit solutions and asked tech support about the problems Iím having.They said I was the third person who called about the high low problem.They already have come up with a solution as there is a isolated issue with some of the new harnessís.He said he would ship it out ASAP,So sounds like that problem is solved.
They didnít have any idea about my [ ] not going to full power.I told them about Forscan and he told me there is no need to do that that the harness solves everything,Should work factory right out the gate.
I have contacted three people that have done the conversion all the way down to XL trucks and all have worked flawlessly.Im still going to look into Forscan like you guys suggested.
Old 02-22-2019, 09:08 AM
GABAR's Avatar
GABAR
GABAR is offline
GABAR has a good reputation on FTE.GABAR has a good reputation on FTE.GABAR has a good reputation on FTE.
LOL......Sounds like "Dejavu".
A few years back, they had harness problems with 2015-2017 F150 owners attempting the same OEM LED headlight swap.
Old 02-28-2019, 07:32 PM
nico963's Avatar
nico963
nico963 is offline
**Update** Well after taking the whole front of my truck off again to see if I could figure out why my [ ] wouldn't go to full bright when put it in drive,Long story short It was my ground....It wasnt a good enough ground for the headlights to work properly where I had It.Fixed that and everything works as it should now besides the bright lights.Morimoto still has to send out the adapter for them to work.
Thanks again for the help.
Old 03-04-2019, 10:20 PM
Afasano
Afasano is offline
Afasano is starting off with a positive reputation.
With that harness do the drlís dim when the headlights are on, or stay at full bright all the time?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
