Sponsored by: Halo Lifts
2018 lock problems?
Old 02-16-2019, 11:11 AM
Buck268's Avatar
Buck268
Buck268 is offline
2018 lock problems?
Recently purchased a new 2018 F150 Screw and noticed something interesting now that we have actually had a few weeks of winter weather. It seems like the power locks somewhat randomly don't work. By this I mean, last week the right rear door power lock would not work; yesterday the driver front door power lock wouldn't work very well. In both cases they could easily be locked and unlocked manually. Is this consistent with the TSB I read on the 2015-2017 models and freezing locks? To me, if the lock freezes it shouldn't work manually either, right?
Due for the first oil change in the next week or so, so I will have the dealer inspect but I'd love to hear any info out there as I"m sure they will be "unable to reproduce."
Old 02-16-2019, 03:17 PM
GABAR's Avatar
GABAR
GABAR is offline
Since it`s new and still under the factory warranty, let your dealer look at it and try to figure it out.
With that being said, I`ve heard about the TSB involving doors not closing or opening but nothing involving the locks randomly not working so perhaps this is another/new issue.
Old 02-16-2019, 03:33 PM
Destroked 450's Avatar
Destroked 450
Destroked 450 is online now
There is a recall on the 2018's for the door locks as well but I think it is the same issue as the older models.
Old 02-16-2019, 04:46 PM
jimmy-six's Avatar
jimmy-six
jimmy-six is offline
I live in So-Cal and had my 2018 serviced last week and asked about the door locks and the possible fire problem in the driverside "B" piller. They did the "B" piller recall but said they were not doing anything about the door lock freezing at this time. I don't go or drive anywhere it'r's cold or snowy so right know I'm not worried abut it. It may be a regional thing..good luck
Old 02-16-2019, 04:48 PM
Midnightmoon's Avatar
Midnightmoon
Midnightmoon is offline
One of the three times that my 2018 has been back for door lock issues, was for the passenger door not locking or unlocking with the power locks. That door also wouldn't open with the outside handle. It was repaired under the frozen door lock TSB.
The latest TSB available is 19-2007. It was just released in late January. Make sure it is applied when your truck goes in.
Old 02-16-2019, 04:51 PM
Midnightmoon
Here is a copy of my latest work order with the correct TSB # for your reference.
Old 02-16-2019, 06:01 PM
Destroked 450
B pillar recall?
Haven't heard about that one.
Old 02-16-2019, 06:10 PM
jimmy-six's Avatar
jimmy-six
Accident will cause electrical fire from insulation. They take it off....
Old 02-16-2019, 07:18 PM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
They use a small explosive charge to activate the pre-tensioners when an accident is in progress. Apparently the charge can ignite the insulation in the B-pillar.
Old 02-16-2019, 09:20 PM
Destroked 450
Thanks! Looked it up, doesn't apply to my super cab.
Old 02-26-2019, 08:55 AM
Buck268's Avatar
Buck268
Buck268 is offline
Thanks!
Old 02-27-2019, 12:21 PM
Buck268's Avatar
Buck268
Buck268 is offline
Well they did the TSB 19-2007 on our 2018 yesterday at the first oil change. When I arrived to pick it up this morning.... the locks still didn't work. I suppose if its a moisture problem its possible that there is still enough moisture left in the mechanism to cause problems. Guess we'll find out as I left it there again.
Old 02-27-2019, 02:30 PM
JKBrad's Avatar
JKBrad
JKBrad is online now
Between f150s, and now Super Duties, you'd think Ford would have updated or redesigned that latch by now.
Old 02-27-2019, 03:04 PM
Midnightmoon
I wish I could tell you that this surprised me. However, nearly the same thing happened to me. There were exactly 6 miles on my truck between the 2nd and 3rd service appointment for my lock issues. I brought it home from the dealer and they were froze again the next morning so I took it directly back.
2000PrettyBaby
1997 - 2003 F150
12-23-2016 10:00 PM
Fix
1947 and Older Ford Trucks
08-11-2006 09:06 PM
gjmdeputy
1997-2006 Expedition & Navigator
12-09-2005 10:30 PM
Bristrew
36
10-10-2005 09:01 PM
Boose
07-01-2004 09:40 PM
Quick Reply: 2018 lock problems?
